Ford_Tech
Vehicle: Ford 2006 F250 6.0 liter powerstroke
Post by Ford_Tech »
I too have the VCM2 and cannot use it due to the firmware difference between bosch’s latest firmware and Ford’s integrated diagnostic software(IDS). After I downloaded bosch’s latest firmware from their website,I wasn’t able to use IDS anymore until I backdated the firmware to the version that IDS is programmed to use. I’ve also got a USB-Link™ 2: Bluetooth Edition, Autoenginuity SP03, IC4COM, & Nav-Link that I’ve yet to try. Does anybody know if any of these others work with Forscan?
JNEDBM
Vehicle: Mondeo, 2.0 TDCI 96 kW, 2001
Post by JNEDBM »
Hi all,
I'm using a PEAK PCAN-USB adapter with up-to-date passthru driver. Can high and low are connected to HS can bus of Ford Mondeo 2001+.
J2534 adapter is found in ForScan (Adapter: PCANPT32) but it does not connect to vehicle (no communication, check that ignition is on).
Any ideas how to get that working?
Best regards!
bijulal37
Vehicle: Explorer/2012
Post by bijulal37 »
I have cardaq plus 2, that works excellent.Thanks for software creators.
Csubakka
Vehicle: Mondeo Mk4, 2.0 TDCI 140hp, 2012
Post by Csubakka »
Anybody has tried genuine VAS 5054A with FORScan?
amr1999
Vehicle: Ford Fusion
Post by amr1999 »
Hi i have jdiag elite pro support j2534-1 and j2534-2 but it cant read ms-can ecu any idea to solve it and thank you
achiko0077
Vehicle: ford fusion hybrid 2.5 2010
Post by achiko0077 »
Which OBD port would you recommend?
V3lmu
Vehicle: VAG, Ford etc.
Post by V3lmu »
Hello!
I have a genuine AVDI diagnostic device https://abrites.com/en/products/avdi
I tried to use an AVDI device and FORScan software Ford Mondeo MY03. I selected AVDI as the device that was in the menu, but the program did not recognize the car. What did I do wrong? Can't I get in my car with this device & software? :cry:
EDIT 26.1:
I bought an J1850 adapter for AVDI and also tried to connect to the car with this one. I checked the settings again.
https://ibb.co/R6p2S8z
The program finds the car, but ... no connection is found.
https://ibb.co/RTsLrxZ
If I press the button yes
Code: Select all
(OK) [20:35:37.403] Connection to adapter has been established: J2534 AVDI-PT XXXXXX
(OK) [20:35:37.404] Adapter:  AVDI-PT XXXXXX
(OK) [20:36:53.781] Connection to vehicle has been established
(OK) [20:36:53.801] Vehicle: Ford Mondeo DURATEC-HE / I4 1.8L 2001 MY
(OK) [20:36:55.632] Found module:  OBDII - On Board Diagnostic II
(OK) [20:36:57.514] Found module:  PCM - Powertrain Control Module
(ERR) [20:36:58.772] PCM: Unable to read DTC
(OK) [20:36:58.776] Found module:  IC - Instrument Cluster
(ERR) [20:37:00.606] IC: Unable to read DTC
(OK) [20:37:03.051] Found module:  RCM - Restraint Control Module
(ERR) [20:37:04.274] RCM: Unable to read DTC
(OK) [20:37:04.278] Found module:  GEM - Generic Electronic Module
(ERR) [20:37:05.499] GEM: Unable to read DTC
(OK) [20:37:07.947] Found module:  ABS - Antilock braking system
(ERR) [20:37:09.169] ABS: Unable to read DTC
If I press the button no:
https://ibb.co/fpGpGH6
V3lmu
Post by V3lmu »
V3lmu wrote: Sun Jan 24, 2021 11:07 am Hello!
EDIT 26.1:
Code: Select all
Would there be a solution to my problem?
In response to some posts about the VAS5054A
It is a J2534-1 device and can not access the Medium Speed Network
Specifications:
K line (ISO9141-2)
High-speed CAN (ISO 11898-2)
Low-speed CAN (ISO 11898-3)
J1850 (SAE J1850)
UDS Protocol
PWM Protocol
A recent test with the new Ford VCM 3 and setting it as a Pass-Thru device worked out quite well.
FORScan and the device will connect via USB and WiFi.
