2014 explorer ipc flash faild
my 2014 explorer ipc fireware flash faild .
- ipcfaild.txt
- (2.47 KiB) Downloaded 237 times
- fordsmax471
Re: 2014 explorer ipc flash faild
forscan ver ?
obd adapter ?
obd adapter ?
2.4.3 test20200920 with extended license ,openport 2.0 J2434 , flash other HS module all ok except ipc !
- fordsmax471
did you try that too ?
- fordsmax471
you must program the IPC files separately
first programming---> SBL: boot and Strat: 26-...
second reprogramming---> SBL: boot and Calib: 88-...
I used stop activity buses
how flash one by one ,use "stop activity buses" ?
- fordsmax471
first test at the beginning without modification "stop activity buses"fbstn wrote: Mon Oct 19, 2020 5:13 pm I used stop activity buses
- fordsmax471
only this
i hope you have a backup of the IPC as built data as it needs to be reloaded after a successful installation
first programming---> SBL: boot and Strat: 26-... don't use stop buses
second reprogramming---> SBL: boot and Calib: 88-...use stop bues
is it right?
is it right?
- fordsmax471
nofbstn wrote: Mon Oct 19, 2020 5:30 pm first programming---> SBL: boot and Strat: 26-... don't use stop buses
is it right?
first programming---> SBL: bootloader and Strat: ET4T-14C026-BL
and
second reprogramming---> SBL: bootloader and Calib: ET4T-14C088-BL
