v2.3.40 Fails Write - Incompatible Configuration
TX_Jax
Vehicle: F350, 7.3L, 1999
Post by TX_Jax »
Issue: FORScan will not write to Generic Electronic Module.
Vehicle: 1999 Ford F350 7.3L Lariat 2-wheel drive manual transmission
Steps:
Connect to vehicle
Click on "computer chip" Icon
See two entries for Tire Size and Axle ratio "not configured"
Choose proper listing from the drop down menu
Click on Write icon.
Receive error "Writing blocks failed - incompatible configuration
Seems like dropdowns are not sending properly formatted variable to be written
FORScan v2.3.40 beta on Windows 10
Writing to GEM 1 Notation 2021-05-19 143849.jpg (79 KiB) Viewed 5830 times
LaForge
Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
Re: v2.3.40 Fails Write - Incompatible Configuration
Post by LaForge »
I have the same issue using Forscan 2,43 April21 on my Focus 2011
with BV6N-BCM Module.
best regards
Karsten
Changed on my 2011 Focus:
garymarlin
Vehicle: Focus DW10C 140PS 2013
Post by garymarlin »
I had the same with my FF3. FORScan v.2.3.42 with Viaken v3.
Try to delete the profile and let FORScan read all the modules. Then, try to write changes to the configuration in the same session.
It worked for me.
bnvill84
Vehicle: Focus, 2.0, 2014
Post by bnvill84 »
I am having the same issue with my 14 Focus after having to replace the IPC. But I kind of expected to have some hiccups since it's the cluster from a 2019 Escape.
@garymarlin I will try your method so I can get the IPC and secondary central config to mirror the main on the BCM. Also will have to modify vehicle type, VIN, engine, milage, etc...
garymarlin
bnvill84 wrote: Tue Oct 05, 2021 9:25 pm I am having the same issue with my 14 Focus after having to replace the IPC. But I kind of expected to have some hiccups since it's the cluster from a 2019 Escape.
Did you try it? Worked well?
