PATS for 2010 FG Falcon
oldtinfords
Re: PATS for 2010 FG Falcon
Post by oldtinfords »
gmau69 wrote: Thu Jul 16, 2020 2:25 am I helped Forscan guys with MK2 control modules, so it should happen one day.
That’s great. Any help they can get can only make it happen sooner 👍🏼
Sajid Khan
Vehicle: Ford falcon Barra 4.0l 2010
Post by Sajid Khan »
FORScan wrote: Sat May 25, 2019 6:21 am Function for 2008-2010 FG has being successfully tested (confrimed as working by 2 testers) and will be included in the nearest release (2.3.23). So we guess the issue is closed. Function for FG Mk2 is not developed yet but will do.
Hi i am not able to run Pats on my 2010 fg1
I changed BEM and was wondering if there's a way to program a new BEM step by step
Any help would be appreciated
Thanks in advance
patb69u
Vehicle: 2011 ford falcon fg xr6t 270t barra
Post by patb69u »
When will mk2 fg and Sz/2 territory pats be available??
markleo
Vehicle: sz2 territory diesel 2.7l
Post by markleo »
Hi, I'm trying to program an szii diesel territory sold in Australia. It is hard to get accurate information
They say it's 2012 and needs online incode
I have cwp2 which is old type and it fails and says incorrect code
When I use vxdiag it asks for username password and nhtsa LIC
I see people have had success with forscan but I can't see the option on forscan
Should it show greyed out without extended lic
markleo
Post by markleo »
patb69u wrote: Wed May 12, 2021 10:45 am When will mk2 fg and Sz/2 territory pats be available??
Did U have any solution for szii
oldtinfords
markleo wrote: Tue Dec 21, 2021 2:01 am Hi, I'm trying to program an szii diesel territory sold in Australia. It is hard to get accurate information
AFAIK, it can't be done on the SZII but I could be wrong. If you're going to have any chance, you'll nee the extended licence. Not sure why you'd think it might be possible without it.
AFR
Vehicle: Falcon XR6T Sprint I6T 4000cc 370Kw
Post by AFR »
PATS Changed September 2010 . Even with IDS you need dealership logon to achieve PATS. I know Forscan is working on it but the encryption coding has doubled in size . There was a rumour Ford was going to release the codes to snap on but haven't seen this happen yet and no more talk about it .
abs351
Vehicle: FG xr6 turbo I6 4ltr 270kw 2013
Post by abs351 »
Has there been any traction from the forscan team for PATS on MK2 falcon?
Interested to try this and if in need help the team as I have an FG mk2
oldtinfords
If you've got a paid extended licence, message FORScan support directly with your needs & offer to assist. If you don't, buy one, they're cheap.
I believe the problem with FGII PATS programming may be with the incode/outcode calculator but could be wrong.
They are currently assisting me with a FGI that would randomly immobilise & when we tried a parameter reset, it completely immobilised. We couldn't get to do a parameter reset successfully using the current or previous versions. They have been great, sending test versions & we have it running again.
It will be taken for a proper drive after work today to see if it's also solved the original issue or if there's still going to be random immobilisation.
oldtinfords
UPDATE to my previous post
FORScan have implemented a fix for FG1 PATS programming where they go into a partial immobilisation. With lot's of praise to the FORScan Team, we have successfully programmed this problematic FGI XR8. It's been on several drives now without a problem. FORScan have identified a bug that stops the Ford factory equipment from being able to reprogram a FG1 that's partially immobilised....It might explain why FG PCM's & Clusters along with keys, BEM get sent to Injectronics when this happens.
The update will be included in their next release.
