Bilsi
Vehicle: 3FA6P0RU4ER278845
Post by Bilsi »
Help please
Any body have EG9T-14G162-DD. Vbf file
I can't find on https://www.fordtechservice.dealerconne ... roduct=IDS website this file for ECU Configuration hardware /BCM FORD FUSION TITANIUM / HYBRID 2014 PLEASE HELP😔
trimax_69
Vehicle: FORD RANGER ,WL-C 2,5 2008
Post by trimax_69 »
Hi may help for ranger 2008 2.5L tdci i just try for change after that. Car can run 150km/h like limiter. Can help for resolve
Regards
MKK777
Vehicle: Ford S-Max 2.0L Powershift WA6
Post by MKK777 »
:arrow: :arrow: good morning
i would like some help please it seems that no one has the files i am missing!! I attach screen , any possible help will be appreciated . thank you
S MAX (3).png (6.47 KiB) Viewed 13755 times
S MAX (2).png (10.42 KiB) Viewed 13755 times
S MAX (1).png (16.29 KiB) Viewed 13755 times
Andreas42
Vehicle: Ford Focus 2.0
Post by Andreas42 »
Hi
How can I open extended configuration page?
See compare screens attached
jedfish
Vehicle: Mazda 2 1.3 2014
Post by jedfish »
i was trying to replace my mazda 2 BCM, first i checked the old BCM Module configuration and it show only one entry "Rain Light Sensor Illuminance Setting", i installed the new BCM came from a mazda 2 in UK(same model, hw/sw version) and checked the module configuration its the same showing only one entry.. i tried checking module as built configuration for both bcm and the entries are the same.. does this mean i dont need anymore configuration for the new BCM to work on my mazda 2? thanks
bcm config.jpg (97.31 KiB) Viewed 10388 times
jedfish
Post by jedfish »
Andreas42 wrote: Thu May 25, 2023 10:10 am Hi
press the play button below
redrum678
Vehicle: 2011 Ford F150
Post by redrum678 »
can anybody help me with calibration files? where can i download them or if anybody has any of them can you please provide them. thanks
Strat: GB5T-14G374-CA.VBF
Cal: GB5T-14G375-DA.VBF
redrum678 wrote: Thu Aug 03, 2023 8:48 pm can anybody help me with calibration files? where can i download them or if anybody has any of them can you please provide them. thanks
GB5T-14G374-CA.VBF
Error: File (GB5T-14G374-CA.zip) Not Found. Please click Return to Download another file
GB5T-14G375-DA.VBF
Error: File (GB5T-14G375-DA.zip) Not Found. Please click Return to Download another file
A shop with IDS on-line or FJDS with a subscription can write the new calibration.
https://www.motorcraftservice.com/diagn ... ountry=USA
Requires a J2534 programming device.
redrum678
Post by redrum678 »
Ecmbuster wrote: Thu Aug 03, 2023 8:58 pm
GB5T-14G374-CA.VBF
GB5T-14G375-DA.VBF
to my understanding, motorcraftservice website no longer works to get any calibration files. ive tried already. thannks though.
Motorcraftservice does work, I was just there and copied the information.
