Good day.
Own vehicle Ford S-Max 2.0 Ecoblue 110kw - 150 hp. Year of production 2019.
I wanted to use FORSCAN to change the power to 140kw, because the engines are the same. But when I open the PCM unit in FORSCAN, the unit tells me it has 180 horses. At the same time, this power had an old TDCI 132kw = 180 hp.
It doesn't even offer me an engine with 190 horsepower, ...
I bought a new car, no one else did anything about it.
Can anyone advise me who has already encountered this?
Thank you
Change performance using FORSCAN
Re: Change performance using FORSCAN
I suppose that we have the same engine and want the same thing
Did you found solution RSWRC ?
Last time when I checked Forscan show me that I have also Panther Diesel B 180PS, what is obviously wrong reading because I have 150PS.
Has anyone else noticed the wrong reading on these EcoBlue engines?
- a1.jpeg (14.53 KiB) Viewed 3710 times
tastierista
- Vehicle: Smax, 2.0 lt 150hp, 2019
i have the same iusse
Ho lo stesso problema
Qualcuno ha risolto?
Grazie
Grazie
