Change performance using FORSCAN
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Post by RSWRC »
Good day.
Own vehicle Ford S-Max 2.0 Ecoblue 110kw - 150 hp. Year of production 2019.
I wanted to use FORSCAN to change the power to 140kw, because the engines are the same. But when I open the PCM unit in FORSCAN, the unit tells me it has 180 horses. At the same time, this power had an old TDCI 132kw = 180 hp.
It doesn't even offer me an engine with 190 horsepower, ...
I bought a new car, no one else did anything about it.
Can anyone advise me who has already encountered this?
Thank you
FujiiX
Vehicle: Ford S-Max, 2.0 140kW, 2020.
Re: Change performance using FORSCAN
Post by FujiiX »
I suppose that we have the same engine and want the same thing ;)
Did you found solution RSWRC ?
Last time when I checked Forscan show me that I have also Panther Diesel B 180PS, what is obviously wrong reading because I have 150PS.
Has anyone else noticed the wrong reading on these EcoBlue engines?
tastierista
Vehicle: Smax, 2.0 lt 150hp, 2019
Post by tastierista »
i have the same iusse
venangelo
Vehicle: FORD ECOSPORT 1.5 ECOBLU 100 CV 2018
Post by venangelo »
Ho lo stesso problema
Qualcuno ha risolto?
Grazie
