JCGBE3 wrote: Sun Feb 20, 2022 3:19 am Hello, I can't download the file, it tells me that I don't have access, can you give me access or send me the file, thanks
AsBuiltHackerSetup.msi
https://drive.google.com/file/d/0Bw7jDv ... luQ1E/view
isidoro109
- Vehicle: Ford Transit Custom 130 ecoblue
Im interested too.
As build fiesta mk8
Hi, anyone have as build data for mk8 fiesta?
Thanks Miktt!!
CEI Confige
Any one have an idea of how to reset the CEI Lock Configuration once it is ran in a 2017 F250. My son ran it by mistake
STAFFORDAUTOTECH
- Vehicle: Transit 250 , 3.7 , 2019
Any one can help with a spreadsheet for 2019 ford transit 250, I’m trying to activate the cruise control . Thank you.
As-Built Factory IPMA Config for 2022 XLT 302A
Can someone please send me their factory as-built IPMA for 2022 XLT 302A? I am having some configuration issues and I want to restore to factory. Silly me forgot to back up first. Thanks.
Ford Barra
- Vehicle: Ford Falcon BA, Petrol I6, 182kW, 2003
Gidday Forscan users,
Would anybody have the full "As Built Data files" for an Australian Ford Falcon 2003 standard petrol i6 Sedan Automatic 4 speed with no traction control, Single Zone A/C, Because Ford Australia no longer have or keep the As Built files I need such files so I can flash them into a working but used wreckers blue BEM because my original blue BEM is faulty as confirmed by my local Auto electrician. Thanks Barra
oldtinfords
Not necessary. Just install another BEM & use the config option. There's not much that can be changed on an old BA Falcon often, nothing needs to be changed. You will need to carry out PATS programming.Ford Barra wrote: Sat Apr 22, 2023 7:24 am Gidday Forscan users,
Would anybody have the full "As Built Data files" for an Australian Ford Falcon 2003 standard petrol i6 Sedan Automatic 4 speed with no traction control, Single Zone A/C, Because Ford Australia no longer have or keep the As Built files I need such files so I can flash them into a working but used wreckers blue BEM because my original blue BEM is faulty as confirmed by my local Auto electrician. Thanks Barra![]()
hello friends,
I need your valuable help, I have problems when programming the ABS module of my Fors Escape 2013, I use the vLinker FS interface
sincerely
sincerely
