isidoro109
Vehicle: Ford Transit Custom 130 ecoblue
Post by isidoro109 »
Im interested too.
JCGBE3 wrote: Sun Feb 20, 2022 3:19 am Hello, I can't download the file, it tells me that I don't have access, can you give me access or send me the file, thanks
AsBuiltHackerSetup.msi
https://drive.google.com/file/d/0Bw7jDv ... luQ1E/view
picky
Vehicle: 1.0 ecoboost engine specialist
As build fiesta mk8
Post by picky »
Hi, anyone have as build data for mk8 fiesta?
miktt
Vehicle: Ford Fiesta MK8
Post by miktt »
picky
Post by picky »
Thanks Miktt!!
beachs
Vehicle: Ford f-250 6.7 2017
CEI Confige
Post by beachs »
Any one have an idea of how to reset the CEI Lock Configuration once it is ran in a 2017 F250. My son ran it by mistake
STAFFORDAUTOTECH
Vehicle: Transit 250 , 3.7 , 2019
Post by STAFFORDAUTOTECH »
Any one can help with a spreadsheet for 2019 ford transit 250, I’m trying to activate the cruise control . Thank you.
niididdy
Vehicle: 2022 F-150 XLT 302A POWERBOOST
As-Built Factory IPMA Config for 2022 XLT 302A
Post by niididdy »
Can someone please send me their factory as-built IPMA for 2022 XLT 302A? I am having some configuration issues and I want to restore to factory. Silly me forgot to back up first. Thanks.
Ford Barra
Vehicle: Ford Falcon BA, Petrol I6, 182kW, 2003
Post by Ford Barra »
Gidday Forscan users,
Would anybody have the full "As Built Data files" for an Australian Ford Falcon 2003 standard petrol i6 Sedan Automatic 4 speed with no traction control, Single Zone A/C, Because Ford Australia no longer have or keep the As Built files I need such files so I can flash them into a working but used wreckers blue BEM because my original blue BEM is faulty as confirmed by my local Auto electrician. Thanks Barra ;)
oldtinfords
Post by oldtinfords »
Ford Barra wrote: Sat Apr 22, 2023 7:24 am Gidday Forscan users,
Not necessary. Just install another BEM & use the config option. There's not much that can be changed on an old BA Falcon often, nothing needs to be changed. You will need to carry out PATS programming.
Jonh07
Vehicle: Ford Escape 2013 1.6 turbo
Post by Jonh07 »
hello friends,
I need your valuable help, I have problems when programming the ABS module of my Fors Escape 2013, I use the vLinker FS interface
sincerely :cry:
