jSONBB
Vehicle: 2002 Ford Escape 3.0 V6
Post by jSONBB »
jSONBB wrote: Thu Jan 05, 2023 8:50 pm nonContinuousModeDetailedReport_2002__Ford__Escape__GLOBAL_OBDII__01052023152506.pdf
Report of non Continuous DTCs as reported by the Mitchell MD-350. FORScan does not know what multiples of these tests are - gives incorrect data output. I will update this with the list of DTCs from FORScan later today for comparison.
These are the missing "unknown" tests from FORScan, the Mitchell J2534 correctly reports them.
Correct test data pids
Pls update these in FORScan :)
jSONBB
Post by jSONBB »
Ecmbuster wrote: Sun Jan 08, 2023 1:24 am
This is how MODE 6 is identified with FORScan with a J2534-2 device and Bluetooth adapter.
You are incorrect trying to operate that tool, all it did is generate a report from itself, NOT FORScan!
I do understand how to operate this tool, I am trying to show comparison for test data that FORScan doesn't understand; as it shows "unknown" in the Mode 6 list.
Bosch M-VCI (Mastertech)
https://www.boschdiagnostics.com/softwa ... osch-m-vci
Install Windows 7
1) M-VCI_Setup_v13.2.6.exe
2) M-VCI_Setup_v13.3.18.exe
Go to C:\Program Files (x86)\Bosch\VTX-VCI\VCI Software (M-VCI)\J2534 Configuration
Send J2534ConfigApp.exe to desktop
Install Windows 10
Use compatability mode for Windows 7 for both files
Use the USB connection NOT WiFi for diagnostics and programming.
All other applications will be on the desktop - Success with a 2020 F150 5.0L 4WD
djdekl
Vehicle: Focus MK3.5 1.5 134kW
Post by djdekl »
I can't program the BCMI Ford Focus MK 3.5 with the original UCDS cable. Message: the cable is not suitable. Everything worked last week.
I use: Forscan, IDS, FDRS, UCDS, Fordiag
stimpy88
Vehicle: Ford Mondeo Mk5 - Diesel 2.0, 150, 2017
Post by stimpy88 »
Isn't UCDS basically ransomware now? Maybe your cable "phoned home"? I hear they no longer sell tokens or hardware, yet they don't unlock the software.
We always said UCDS was a nasty business model that leaves you at the mercy of the developer and their shady token based system.
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
I have been using UCDS for more than two years now and i never had an issue with,all you have is connecte it to internet once a week to activate the license,Ford softwares IDS,FDRS,FJDS use the same system to be activated and the license is specific to one laptop,Forscan uses two months free license or one year payed one,all these softwares are complimentary ones at list forIDS Forscan and UCDS for diagnosis,modules programming and updates and you need to use all of them some times when the vehicle is 2018 or older,both Forscan and UCDS dont have the ability to program PATS for 2011 and newer cars,concerning the tokens,i have never used the ones i have yet.
anonymius
Vehicle: Ford Mondeo MK3 diesel
Post by anonymius »
vilkur
Vehicle: Galaxy 2.2D 200HP 2013
Post by vilkur »
anonymius wrote: Mon Feb 27, 2023 5:41 pm forscan-ucds.jpg
Same problem with the original VCM-II and VCM-3...
Post by tractmec »
vilkur wrote: Fri Mar 17, 2023 1:45 pm
Use the Support instructions at the heading "Providing FORScan Debug Information" at this link https://forscan.org/contactus.html!
guangzhouhuakai
Vehicle: ford F550 7.3L 2020
Post by guangzhouhuakai »
FORScan wrote: Tue Mar 17, 2015 4:14 am
Ecmbuster wrote: CarDaq Plus
Vetronix ES6510 (working with Ford VODU)
DrewTech Mongoose MFC (may not work with all Ford models)
Actia XS
FORScan should work with any J2534 devices, so if all the above devices support J2534, FORScan should be able to work with all of them. CarDaq Plus is some kind of ethalon for J2534, however this tool is quite expensive so we had no chance to obtain it for testing. We would be glad to get a confirmation it works. As for the other devices, it would be interesting to get the tests results too.
I use a J2534 CarDaq Plus 2 to connect to a 2020-2022 Ford Transit, the F550 works fine and is fast, scans all the modules within 10 seconds, but the CarDaq Plus 2 is too expensive and costs almost $1500; if only one It is recommended to use OBDLINK EX for a Ford car, which is economical and fast;
福特进无止境
