modulos
CLEY.TECC
- Vehicle: FORD NEW FIESTA, 1.6 16V TIVCT 130CV 2014
modulos
Hello everyone, good evening, I have several dtc errors, I would like to correct them. I have the following errors:
APIM U0155
BCMii U2101
BCMii U0264
what reasons and how to fix them grateful.
APIM U0155
BCMii U2101
BCMii U0264
Re: modulos
Where are the screen images of the faults and information at the "Modules" Tab?
What did you change / replace, what did you program?
What OBD interface are you using?
APIM U0155 - U0155 Lost Communication with Instrument Panel Control (IPC) Module
BCMii U2101 - Body Control Module (BCM) not configured
BCMii U0264 - Lost Communication With Camera Module-Rear: Missing Message
CLEY.TECC
Re: modulos
the only thing I changed was to add the autopilot, otherwise don't change it.
- WhatsApp Image 2023-05-27 at 21.48.04.jpeg (134.42 KiB) Viewed 1539 times
- WhatsApp Image 2023-05-27 at 21.48.04 (1).jpeg (105.54 KiB) Viewed 1539 times
- WhatsApp Image 2023-05-27 at 21.48.05.jpeg (99.1 KiB) Viewed 1539 times
- WhatsApp Image 2023-05-27 at 21.48.05 (1).jpeg (90.04 KiB) Viewed 1539 times
Re: modulos
Multiple controllers need to be reconfigured because of the addition.
https://forscan.org/forum/viewtopic.php?t=1932
CLEY.TECC
Re: modulos
and now how do i get it?
CLEY.TECC
Re: modulos
my car does not have a rear camera
Re: modulos
Did you read the link?
Are the replacement parts new or used?
Did that model come with that addition in that model year?
Do the original parts and error support the addition?
CLEY.TECC
Re: modulos
as pecas sao usadas e suportam a adicao, essa versao de carro nao tem, mais pode ser adicionadas normalmente.
CLEY.TECC
Re: modulos
Parts are used and support adding, this car version does not, but can be added normally.
Re: modulos
You will need the wiring schematic for your model and the donor that the parts came from.
You will need the correct part numbers and the As-Built data from the donor vehicle.
You will need to adapt and configure the network to accept the added controllers.
The information should have been included at the first post!
