Calibration files
Paulscarbs
- Vehicle: Transit 2.4 RWD
Re: Calibration files
Thank you.Please share the procedure you took to enable standard Cruise.
Brananimal
- Vehicle: 2006 Crown Victoria 4.6
Turns out you were correct! I flashed the pcm with the wrong hardware and have been chasing the issue with this engine swap for about a month. In my ignorance, I didn't save the original calibration files for the pcm I purchased so I was wondering if you could help me find them for a 6C3A-12A650-DGB. I don't have the VIN for the vehicle this pcm came from but it was a 2006MY F-Series Super Duty with a 3v V10. Any help would be appreciated!oldtinfords wrote: Tue Oct 10, 2023 7:40 pmHere's a bit more info so you can make a decision on whether or not to try TBFE3R4 (6U7A-12A650-HBA). Make sure the hardware type is right along with everything else. With the current info provided, I couldn't even guess if ica's suggestion is even remotely close to being right of if it'll just brick the PCM.ica wrote: Tue Oct 10, 2023 10:12 amtry TBFE3R4Brananimal wrote: Mon Oct 09, 2023 8:54 pm Can anyone help me find calibration files for 6C2A-12A650-SC?
Brananimal
Forgot to include this in my previous post, the batch code for my pcm is UGK1 and hardware no. is VK2-C3694. Hope these help with the search. For future reference, how is everyone finding these calibration files? I've tried Motorcraft's website for multiple different strategies and it's very hit or miss whether or not it downloads the files.
oldtinfords
If you saved the vehicle profile, it'll show the strategy. This is required to find the file you need. All these other numbers are listed in the file hex but without opening thousands of files, it's near impossible, unless someone happens to recognise it from their own vehicle. A screenshot of module configuration screen with all the modules listed will provide this.Brananimal wrote: Thu Nov 30, 2023 11:53 pm Forgot to include this in my previous post, the batch code for my pcm is UGK1 and hardware no. is VK2-C3694. Hope these help with the search. For future reference, how is everyone finding these calibration files? I've tried Motorcraft's website for multiple different strategies and it's very hit or miss whether or not it downloads the files.
Brananimal
Sadly I didn't save the vehicle profile either. I searched through my log folder and it didn't display the original strategy or even the full VIN of the vehicle. Guess I'm stuck hoping someone else has the files or buying an identical pcm to retrieve the files from it.oldtinfords wrote: Fri Dec 01, 2023 7:55 amIf you saved the vehicle profile, it'll show the strategy. This is required to find the file you need. All these other numbers are listed in the file hex but without opening thousands of files, it's near impossible, unless someone happens to recognise it from their own vehicle. A screenshot of module configuration screen with all the modules listed will provide this.Brananimal wrote: Thu Nov 30, 2023 11:53 pm Forgot to include this in my previous post, the batch code for my pcm is UGK1 and hardware no. is VK2-C3694. Hope these help with the search. For future reference, how is everyone finding these calibration files? I've tried Motorcraft's website for multiple different strategies and it's very hit or miss whether or not it downloads the files.
oldtinfords
Buying a replacement PCM might be your best option, unless you know of an identical vehicle you can plug into to save a profile etc.
It's unlikely that you will find someone who's going to open thousands of files with a hex editor trying to find the right file, without them being paid an hourly rate.
In the configuring and Programming thread i have Post in the Focus mk4 high beam thread. I cannot make the ipma modul tho Work.
My old was an gx so i have buy an cx model. But all what i do the cam not aktivste. Collission assist and lka assist are disabled when i start the engine. I have make so many calibration drives. But never it have works. No green line.
One idea i have.... My new ipma is a used one and the last idea is what i have is a firmware Update.
In forscan beta it Shows Update is avaible, but cannot Download. Can you help me please?
Current:
To program:
Teilenummer:
JX7T-19H406-CM
Available
Calibration level:
JX7T-19H406-CM
JX7T-19H406-CN
Hardware Nummer:
JX7T-14F403-CA
JX7T-14F403-CA
Secondary Boot Loader:
H1BT-14F399-AB
H1BT-14F399-AB
Strategy (CAN, F188):
JX7T-14F397-AL
N1BT-14F397-AA
Strategy (CAN, F120):
JX7T-14F397-BK
N1BT-14F397-BA
Programmierung (CAN, F124): JX7T-14F398-AK
JX7T-14F398-AL
Programmierung (CAN, F125): JX7T-14F398-BK
N1BT-14F398-BA
The first one are the files what on my ipma, the second the new version. Thank you
I have the firmware files. Buy forscan licence works now!!
But is it a good idea Flash all?
The new files have complete other names on start
Edit:
Firmware flashed succesfull. Still same dtc u2100 first calibration blabla
I will cry
Current:
To program:
Teilenummer:
JX7T-19H406-CM
Available
Calibration level:
JX7T-19H406-CM
JX7T-19H406-CN
Hardware Nummer:
JX7T-14F403-CA
JX7T-14F403-CA
H1BT-14F399-AB
H1BT-14F399-AB
JX7T-14F397-AL
N1BT-14F397-AA
JX7T-14F397-BK
N1BT-14F397-BA
JX7T-14F398-AL
N1BT-14F398-BA
Edit:
I will cry
Can someone please help me find these Calibration Files? The motorcraft service download comes back with a .asp file.
GB5T-14G376-AA
1U5T-14G374-DA
1U5T-14G375-DA
GB5T-14G379-AA
JB5T-14G379-BA
GB5T-14G376-AA
1U5T-14G374-DA
1U5T-14G375-DA
GB5T-14G379-AA
JB5T-14G379-BA
ea5t-14d212-ga calibration files please?
Hi there,
Do you guys have a complete .vbf calibration files for
GB5T-14G375-H*.vbf
It's a Sync 3 APIM HS7T-14G371-FAE.
Thanks in advance
GB5T-14G375-H*.vbf
Thanks in advance
