Ford mondeo mk5 manual from 2019 Panther A
marekrbk
Vehicle: Ford Mondeo mk5 110kw ,2020
Post by marekrbk »
Panther EcoBlue Engine 2.0 110kw .Will it ever be possible to save a new configuration in the pcm to change from Panther A to Panther B.
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Re: Ford mondeo mk5 manual from 2019 Panther A
Post by RSWRC »
It will not increase the power from 110 kw (150 HP) to 140 kw (190 hp).
The 110kw engine has a compression ratio of 16.5:1
The 140kw engine has a compression ratio of 16:1
And changing the map does not change the compression ratio. 150 versus 190 engines are different.
I also have an S-Max 2019 and I have 110kw and Forscan shows me 190. Which is stupid. ;)
marekrbk
Post by marekrbk »
They have exactly the same compression, there are no differences. The reason why it cannot be switched is that the pcm there are missing blocks so it is not possible to switch
Snímka obrazovky 2023-12-14 194746.jpg (99.52 KiB) Viewed 11134 times
marekrbk
Post by marekrbk »
feshworx
Vehicle: Focus Turnier MK2 2.0 TDCi Sport
Post by feshworx »
Yes 🙌 n smax, but many dtc‘s snd you cannit start the engine, but i wont give up
marekrbk
Post by marekrbk »
The manual Mondeo mk5 ecoblue PCM does not have any other blocks, so it cannot be switched.
marekrbk
Post by marekrbk »
Has anyone found a suitable calibration that doesn't give errors and allows switching?
