REMOTE START
Eyia
Vehicle: Focus 4.5 / 1.5 / 2024
Ynt: UZAKTAN BAŞLATMA
Post by Eyia »
Hello I own a focus 4.5 2023 model. What key do I need for remote start?
Blueprintsud
Vehicle: Ford s max
Re: REMOTE START
Post by Blueprintsud »
Hello i dont understand this part here ?
i have a ford s max 2015 i bought the key and i wonder about this part here ?
thanks
Programming keys
:arrow: Place the first programmed key in the backup slot. Press the START / STOP button.
:arrow: Within 5 seconds, place the second programmed passive key in the backup slot, then press the START / STOP button.
:arrow: Within 5 seconds, place the unprogrammed passive key in the backup slot and press the START / STOP button.
Congratulations on your new key being programmed !!! :)
Blueprintsud
Vehicle: Ford s max
Re: REMOTE START
Image[/img][/img][/img]
Blueprintsud wrote: Mon Jan 08, 2024 9:25 pm Hello i dont understand this part here ?
thanks
Programming keys
https://postimg.cc/F1fs7r4x
Blueprintsud
Vehicle: Ford s max
Re: REMOTE START
Now i did program the extra key but i dose not lock or unlock the car just to know if the key works or not any idea ??
thanks
EDIT i got the key to work but i did not like that i cant use my 2 original key
if i find any thing that makes all 3 works i will getback to you
thanks for every thing btw
Blueprintsud wrote: Wed Jan 10, 2024 5:46 pm Image[/img][/img][/img]
thanks
Programming keys
Kevinjeep
Vehicle: Everest gasoline 2.3L Turbo EcoBoost 2020
Re: REMOTE START
Post by Kevinjeep »
Blueprintsud wrote: Sun Jan 14, 2024 2:59 pm Now i did program the extra key but i dose not lock or unlock the car just to know if the key works or not any idea ??
thanks
thanks
Programming keys
Got an idea on how to resolve this problem.
1) Change RTM module AsBuilt value 751-01-01 x2xx xxxx. In this case the new one works, and the 2 old ones don't work.
2) Go to the the PATS programming module to erase all keys.
3) Re-program all 3 keys following instructions by PATS.
At this point, all the keys will work fine?
This is still a though without real test. Not sure if new issues will come out, like the 2 original keys can not be programmed? Please be cautious if you would like to try it out. Good luck..
Updates: I myself have done a test on this theory, no luck. It truns out the 2 original keys still not working although they were sucessfully programmed.
Pigglesberg
Vehicle: 2017 Galaxy Titanium X 2.0 Tdci 150 Powershift
Re: REMOTE START
Post by Pigglesberg »
Kevinjeep wrote: Fri Jan 19, 2024 11:59 am
thanks
I got my remote start working but the 2 original keys no longer work. I'd be interested if someone tested this/found a way to get them all working!!
Kevinjeep
Re: REMOTE START
Post by Kevinjeep »
Pigglesberg wrote: Sat Jan 20, 2024 4:50 pm
thanks
hazlbauer
Vehicle: Mustang GT, 5.0 2019
Re: REMOTE START
Post by hazlbauer »
I have same problem at Mustang GT 2019 EU (Germany) 2 Original Keys is working, and new one working only in emergency slot.
I have original keys JR3T-15K601-DD and new one is JR3T-15K601-ED
I dont know how is a frequency, if this keys not different frequency.
Could you some help me please? I dont see any information on internet of this keys frequency.
Thank you very much.
Jan
Kevinjeep
Re: REMOTE START
Post by Kevinjeep »
From what I understand, the new key, working in the emergency slot one way or another, should be in the same frequency with tow original ones.
As a next step to have it working, you would like to make change to RTM asbuilt.
RTM module AsBuilt value: 751-01-01 x2xx xxxx. Unfortunately, in this case the new one works, and the 2 old ones don't.
Good luck!
keepchooglin
Vehicle: Ford Mondeo 1.6 Ecoboost 160hp 2014
Re: REMOTE START
Post by keepchooglin »
I've Googled that Asbuilt number from the RTM, and stumbled on a Russian topic on the subject. I've translated it to Dutch (my native language) and English and the guy explains all the above. But later on, he says he got all the keys working! Because of the bad translation I don't understand why.. :?:
Maybe someone here can figure it out? This is the topic:
https://www.drive2.ru/l/638297837079114250/
Hope we can resolve this issue now!
Ford Mondeo
MK5 2.0 Ecoboost Vignale 240hp Nocciola Brown estate
full options
