Region And Language for APIM and IPC
shaker1964
Vehicle: Ford Fusion 2000 2017
Re: Region And Language for APIM and IPC
Post by shaker1964 »
Tam5 wrote: Mon Jul 19, 2021 1:42 am Dears
What is the county code for Iraq and how I can change it please?.
IZ 495A - XXXX - XXXX
imranmd75
Vehicle: Explorer, Turbo 2.3L/300,2020
Post by imranmd75 »
I have a 2020 Explorer XLT which has been imported from the US to the UAE. The radio frequencies are odd and the built-in maps are not available. I would like to change the region from the US to Middle East. I've attached the screenshot from my most recent scan of the APIM. What numbers/codes to I need to change in order to set the region to Middle East?
APIM Ford Explorer.png (117.94 KiB) Viewed 5284 times
ACM Ford Explorer 3.png (131.78 KiB) Viewed 5283 times
ACM Ford Explorer 2.png (123.98 KiB) Viewed 5283 times
ACM Ford Explorer 1.png (128.66 KiB) Viewed 5283 times
@ imranmd75
Start reading at the first post.
Your model may be more complex.
Visit a local dealer.
Ask to read the APIM part number is it works / fits your region.
With luck, the dealer can flash the vehicle with the correct firmware, language and maps.
imranmd75
Post by imranmd75 »
I have already been to the dealer but they refused to do any changes.
Contact a smarter dealer.
Does the 2020 Explorer XLT exist in the UAE dealerships?
Find an identical model that operates in the UAE and capture its data.
Save it for review.
andrzejczak82
Vehicle: Ford Kuga 2,0 tdci 100kW 2008
Post by andrzejczak82 »
Hi
I have problem with mustang 2016 with small display radio. On instrument cluster change language on PL but can’t change on radio. Anyone know how to change it?
eyal.tal@gmail.com
Vehicle: 2017 Ford Fusion Energi
Post by eyal.tal@gmail.com »
What is the CODE FOR israel?
TxF
Vehicle: 2020 Escape Titanium 2.0l EcoBoost, 8F35 auto and AWD
Post by TxF »
stala wrote: Tue Jun 20, 2023 5:07 am How to make Polish language in counters in Escape 2020 virtual counter
Jak zrobić język polski w licznikach w Escape 2020 licznik virtual
With ForScan, in both IPC and APIM set "Country Code" to your country, that is "PL".
You can also set ACM "Tuner region value" to "Europe" and APIM "Radio Tuner Type" to "RDS (EUR, APA, SA)" to be able to change frequency every 50 MHz.
And here's how to install EU maps to US Sync3: https://www.fordescape.org/threads/how- ... eu.123362/
zooli74
Vehicle: Ford Mondeo 132kw/2015
Post by zooli74 »
Hello!
Do you need an internet connection to program a language package?
TxF
Post by TxF »
You install languages themselves by installing particular software, maps etc - the packages include different sets of languages. Then you don't need Internet connection to configure/set them (is it through Sync3 or Forscan), but you need to have proper packages installed in the first place to have the language you want.
