I have a genuine VCM3, can I use that with FORScan?
I don't see much mention of this adapter let alone in the official adapter guide here ---> viewtopic.php?f=4&t=26219
Rotunda VCM3 with FORScan?
Re: Rotunda VCM3 with FORScan?
Yes It works same as the VCM2! You will need to get and install the Latest Ford VCI manager as FORScan uses the same manager as Ford IDS/FJDS/FDRS!ELCouz wrote: Sun Oct 13, 2024 10:11 pm Hi,
If you have one of the above Ford Diagnostics already Installed(The Ford install will either install it or prompt you to download and install it) and working with the VCM3 you should already have a VCI manager installed under a "Bosch" folder in your start menu!
Make sure your Connections under the Gear Icon/Connection Tab are set to J2534 under Connection Type and Ford-VCM-III is set in "J2534 Adapter Type"
You can get the latest VCI manager here(VCI Software 1.0.1.18) if you do not already have it:https://www.motorcraftservice.com/diagn ... goryId=276
Hope that answers your question?
