Page 17 of 29
Re: REMOTE START
Posted: Mon Sep 12, 2022 5:05 pm
by slip_n_slide
slip_n_slide wrote: Mon Sep 12, 2022 4:52 pm
fordsmax471 wrote: Mon Sep 12, 2022 4:37 pm
Raiko4 wrote: Fri Sep 02, 2022 6:13 am
Remote start:
BCMii As-built
726-22-02 (2014+ MY) xxxX xxxx xxxx
0 (Disabled)
1 (Enabled)
Is changing this the same as enabling "remote start" from BCMii module?
yes
Do you know if it’s supposed to be the same for S-Max? I tried that option but it didn’t work :/
Thanks again for all your help.
Ignore me, it’s worked. I’m a very happy bunny
Re: REMOTE START
Posted: Mon Sep 12, 2022 5:23 pm
by slip_n_slide
Is there a way to code a second key so I could have two keys with remote start? I tried repeating the process but it wouldn’t let me do another
Edit: in case it makes a difference… it’s showing 4 admin keys but I have three. Two three button and one 4 button.
Re: REMOTE START
Posted: Mon Sep 12, 2022 5:25 pm
by TRIROG
TRIROG wrote: Sun Aug 28, 2022 6:40 am
So i got the aftermarket key.
https://m.aliexpress.com/item/100500263 ... f19cBo2eVo
Next step was to add it to my 2019 SMax
I tried all the suggested programming methods but was totally unsucessful.
I tried the steps written, even tried holding the start/stop button at the Last step instead of just push&release.
Hmmmm…come to think of it, the idea is to push and realease the start/stop bitton at each step right, not to hold it down for 5 seconds?
I learned that there might be an issue if the key is 80bit instead of 40bit or something like that …
Follow up:
Went to the dealer and 35€ later (for key programing) i have 3 keys, however the chinese aftermarket key only works in backup slot, so i guess i need to change the settings now …
Is there any sure way to avoid the pricey key lottery?
Re: REMOTE START
Posted: Mon Sep 12, 2022 5:50 pm
by TRIROG
ReNeGaDo wrote: Wed Jan 27, 2021 3:42 pm
Hi there , first of all thanks to fordsmax471 for all help he brings to us not only with the remote start but in many other threads, definitely if you come to Spain and you come to Alicante area I owe you a homemade paella
Well now I think its my turn to give my feedback and experience from all of this and maybe add it to the main post.
I have a 2019 Smax 2.0 ecoblue 190cv Auto 8speed gearbox and this are all the "issues" Ive encountered and how did I ended up fixing them:
-Cant add any of the 2 keys Ive bought to be admin , my car has this functiom disabled , had to go to ford and 25€ after had the keys added.
-When I tried to do a remote start nothing happenned
. One of the conditions for remote start to work is to have the battery with enough charge , so please make sure you charge your batteries with a charger that supports our
AGM batteries otherwise it wont charge properly. also DO NOT plug the (
-) polarity directly to the battery as it will mess with the BMS ( battery monitor system) that again can mess with remote start.... ( it did in my case
). also when fully charged its recommended to reset BMS module or leave the car closed without use during 8 hours so it will allow all system to work again.
- To start the car with remote start normally once car is closed you have to press 2 times the button, of course in my case this would not work, even if its already closed I have to press lock button and then 2 times the start button , then it will start
Regards to all of you guys
again fordsmax471 and also the polish guys fron youtube THANKS
@Renegado If You read this, do all three keys work or did you have to change the RTM settings?
Re: REMOTE START
Posted: Mon Sep 12, 2022 6:09 pm
by fordsmax471
I did not change the RTM module
Re: REMOTE START
Posted: Mon Sep 12, 2022 9:32 pm
by TRIROG
Can you share the model of your original key?
Mine is hs7t-15k601DD and i bought aftermarket HS7T-15K601-ED/DS7T-15K601-EF 433 version, is it possible that that is the issue and i should need 434MHz version?
Re: REMOTE START
Posted: Tue Sep 13, 2022 5:02 pm
by fordsmax471
please see the beginning of this post
Re: REMOTE START
Posted: Tue Sep 13, 2022 6:00 pm
by slip_n_slide
slip_n_slide wrote: Mon Sep 12, 2022 5:23 pm
Does anybody know? Would love to have a second key
Thanks everyone for all the help with their posts.
Re: REMOTE START
Posted: Tue Sep 13, 2022 7:11 pm
by fordsmax471
a total of 4 keys can be installed
if you already have 4 admin keys, you need to delete one in the ford dealer service
but it is about €200 worth of work
Re: REMOTE START
Posted: Tue Sep 13, 2022 9:04 pm
by TRIROG
fordsmax471 wrote: Tue Sep 13, 2022 5:02 pm
What i cant seem to find is how to correctly identify 434 or 433 mhz.
I saw you were mentioning etis but i have no access to etis.
