REMOTE START
- fordsmax471
Re: REMOTE START
vin no.
Re: REMOTE START
Sent via PM
vankeo2009
- Vehicle: 2022 Ford Raptor
Re: REMOTE START
Hello admin and all mebers
I would like to configure the remote start for 2023 Ford Ranger Raptor from Thailand , Anyone could advise me please ?
https://web.facebook.com/FordSoftwareUp ... 1620719962
Thank you >
Regards
Thank you >
Regards
vankeo2009
Re: REMOTE START
Hello all member and Admin
After I update the latest software, the software can communicate with car but it could not write configuration and programming.
please check the video in attachment.
Regards
Regards
- 2023 ranger raptor.mp4
- (128 KiB) Downloaded 405 times
Re: REMOTE START
I was able to program the 3rd key with the 4 buttons to the car (2017 Ford Galaxy 2.0TDci automatic EU, Hungary) (I ordered this aftermarket key: CN18093 HS7T-15K601-ED, saying 433.92MHz FSK. https://www.aliexpress.com/item/1005002630590761.html).
The car recognizes the new key when the key is in the programming slot, and the MyKey in the "left speedometer menu" shows that I have 3 keys, but the remote buttons do not work at all (lock, unlock, tailgate, remote start). The two original keys work as the should.
I did the changes only in IPC and BCM to enable RS, and I enabled RS in the speedometer menu as well.
The original key is HS7T-15K601-DC. Etis says that the is frequency - 433MHZ.
Does anyone have any ideas what else should I do?
Did I choose a key with a bad frequency?
Re: REMOTE START
Most RKEs operate at a frequency of 315 MHz for North America-made cars and at 433.92 MHz for European, Japanese and Asian cars.
Measure your existing keys to match.
ttps://www.youtube.com/watch?v=okFbmDsC8Kk
https://www.youtube.com/watch?v=OLKZKwrrgxo
https://www.youtube.com/watch?v=awNymWFQSdo
Re: REMOTE START
I went to a car key replace guy to ask about the frequencies. A light blinked for both the new and the old remote in his testing tool and he said both of them operate at 433MHz. I asked aboid the 434 variant and frequency differences. He said it does not matter, but he was not able to show me the frequency as a single number like in the recommended videos. He also said that for programming a key to a car I need special programmer tool, he did not believe me I just followed fordsmax471's instructions.Ecmbuster wrote: Fri Nov 11, 2022 3:39 am Most RKEs operate at a frequency of 315 MHz for North America-made cars and at 433.92 MHz for European, Japanese and Asian cars.
I try to go to an other key-guy to check the base frequency of the remotes - as shown in the linked video(s).
Re: REMOTE START
hi ive done the above and i get the remote working for locking and unlocking and boot but the car will not startfordsmax471 wrote: Tue Dec 17, 2019 6:19 pm Hi !
Remote start the car ( Ford S-Max 2.0 TDCi 2017 PowerShift )
4Button Remote smart Key 433 or 434 MHZ DS7T-15K601-EF (please see ford etis )
guide for Ford S-Max mk2
To activate Remote Start, first you need a new key fob with start button (part # DS7T-15K601-EF for S-Max mk2 with 434 MHz).
Note ! remove the metal blanks from the keys, the car doors are closed and the handbrake deactivated.
Programming keys
Determine the backup slot of the passive key
Place the first programmed key in the backup slot. Press the START / STOP button.
Wait for 4-5 seconds, then press the START / STOP button.
Extract the first programmed passive key.
Within 5 seconds, place the second programmed passive key in the backup slot, then press the START / STOP button.
Wait for 4-5 seconds, then press the STOP-STOP button.
Extract the second programmed key.
Within 5 seconds, place the unprogrammed passive key in the backup slot and press the START / STOP button.
Car doors lock and opened, lights blink
Congratulations on your new key being programmed !!!![]()
Now use Forscan to change the asbuilt-data
BCM module- configuration parameters
• Remote start - enable
IPC module - configuration parameters
• Remote start - climate settings- enable
• Remote start - front seat- enable (optional)
• Remote start - rear defrost – enable (optional)
• Remote start - steering feel – enable (optional)
some guides recommend
RTM module - configuration parameters
• don't change anything( old keys can also be used in the future )
when you double press 2x
can someone pls give me some advise.
my car is a ford galaxy titanium X MK4 Diesel with power shift....
thanks in advance
- fordsmax471
Re: REMOTE START
in the instrument panel you have the remote system option activated
lock the car and press then lock 1x and remote start 2x
Re: REMOTE START
After re-reading the whole forum topic to find a solution, finally I solved (partially) my problem by changing RTM module AsBuilt value 751-01-01 to x2xx xxxx. The solution is partial, as the new 4 button remote works as expected, but the 2 original keys don't work anymore as remote, as others mentioned before:kovlo wrote: Fri Nov 11, 2022 12:50 am I was able to program the 3rd key with the 4 buttons to the car (2017 Ford Galaxy 2.0TDci automatic EU, Hungary) (I ordered this aftermarket key: CN18093 HS7T-15K601-ED, saying 433.92MHz FSK. https://www.aliexpress.com/item/1005002630590761.html).
fordsmax471 https://forscan.org/forum/viewtopic.php?p=50946#p50946
andyh1108 https://forscan.org/forum/viewtopic.php?p=69629#p69629
dlvs77 https://forscan.org/forum/viewtopic.php?p=55811#p55811
flashedbg https://forscan.org/forum/viewtopic.php?p=75719#p75719
The operating distance is under investigation, the current maximum is 50m, having only vegetation in the line of sight to the car.
Thank you very much for every helpful contribution!
