I send back to you translated ia a couple of days
FORScan Lite Beta for Android
Ok received the text by mail.
carlus
- Vehicle: MAZDA CX7 MZR CD 2.2 2010
This option is also quite interesting as it avoids having to look at the screen of the mobile when you're driving.FORScan wrote:As mentioned previously, this feature is planned to be implemented in future releases, will not be included in the first release.skauber wrote:I think it would be good to implement an alarm like that as well, even if it only works when the app is in the foreground, as to alert a driver if some value goes too high or too low when hes busy looking at the road and not the app.
The idea is that if you want to control , for example , when a DPF regeneration occurs or if you 're going through a certain speed , the phone rings ... and then you realize that "something" happens .
I wish development plan soon.
A greeting.
MAZDA cx7 diesel
Maybe i missed this, but is it possible to execute service procedure through forscan for android?
Yes - you missed it. There are no extended functions in the android and iOS versions.
The developers say it is unsafe. On android the apps can be stopped / ended any time by memory management for example. If this happens in the middle of a timing critical service procedure...
Ok, i get the picture. Bot on the other hand, i occasionally have such cases on windows platform. Especially when injector calibration is going on. But this still can be solved with little patience and time
szemisun
- Vehicle: Ford Mondeo Turiner MK4 2.0 TDCi 163 Hp 2011
Hello
Would you send me the resource file, because i would like to help you to translate it to hungarian.
btw, this app is fantastic, i love it!
Thanks,
G
Thanks,
G
13313888066
- Vehicle: ford kuga,2.0,2013
For some reason I can't save to CSV on my phone. It saves to FSL without any problems but when I try to save to CSV it throws "unable to save".
I have FORScan folder in Download and I can copy the FSL files - wont save to CSV....
Thank you very much
I have same problem. Android 7.0. it can save .fsl files but .csv files it gives the error unable to save file. Is there a separate application this export is dependent on? Also any way to convert.fsl to csv? Haven't tried it myself yetveeefour wrote:For some reason I can't save to CSV on my phone. It saves to FSL without any problems but when I try to save to CSV it throws "unable to save".
