Ynt: UZAKTAN BAŞLATMA
Posted: Tue Jan 02, 2024 7:19 pm
Hello I own a focus 4.5 2023 model. What key do I need for remote start?
Software scanner for Ford, Mazda, Lincoln, Mercury vehicles
https://forum.forscan.org/
https://postimg.cc/F1fs7r4xBlueprintsud wrote: Mon Jan 08, 2024 9:25 pm Hello i dont understand this part here ?
i have a ford s max 2015 i bought the key and i wonder about this part here ?
thanks
Programming keys
Place the first programmed key in the backup slot. Press the START / STOP button.
Within 5 seconds, place the second programmed passive key in the backup slot, then press the START / STOP button.
Within 5 seconds, place the unprogrammed passive key in the backup slot and press the START / STOP button.
Congratulations on your new key being programmed !!!![]()
Blueprintsud wrote: Wed Jan 10, 2024 5:46 pm[/img][/img][/img]
thanks
Programming keys
Got an idea on how to resolve this problem.Blueprintsud wrote: Sun Jan 14, 2024 2:59 pm Now i did program the extra key but i dose not lock or unlock the car just to know if the key works or not any idea ??
thanks
EDIT i got the key to work but i did not like that i cant use my 2 original key
if i find any thing that makes all 3 works i will getback to you
thanks for every thing btw
thanks
Programming keys
I got my remote start working but the 2 original keys no longer work. I'd be interested if someone tested this/found a way to get them all working!!Kevinjeep wrote: Fri Jan 19, 2024 11:59 amGot an idea on how to resolve this problem.Blueprintsud wrote: Sun Jan 14, 2024 2:59 pm Now i did program the extra key but i dose not lock or unlock the car just to know if the key works or not any idea ??
thanks
1) Change RTM module AsBuilt value 751-01-01 x2xx xxxx. In this case the new one works, and the 2 old ones don't work.
2) Go to the the PATS programming module to erase all keys.
3) Re-program all 3 keys following instructions by PATS.
At this point, all the keys will work fine?
This is still a though without real test. Not sure if new issues will come out, like the 2 original keys can not be programmed? Please be cautious if you would like to try it out. Good luck..
I myself have done a test on this theory, no luck. It truns out the 2 original keys still not working although they were sucessfully programmed.Pigglesberg wrote: Sat Jan 20, 2024 4:50 pmI got my remote start working but the 2 original keys no longer work. I'd be interested if someone tested this/found a way to get them all working!!Kevinjeep wrote: Fri Jan 19, 2024 11:59 amGot an idea on how to resolve this problem.Blueprintsud wrote: Sun Jan 14, 2024 2:59 pm Now i did program the extra key but i dose not lock or unlock the car just to know if the key works or not any idea ??
thanks
