REMOTE START
colin39
Vehicle: ford ranger 3.2cc 201bhp 2019
Re: REMOTE START
Post by colin39 »
Only works on 2023-> dunno why. I haven't tried on the Mondeo but on the ranger only the next gen works on both key types
panchevks
Vehicle: Mondeo, diesel 2.0 tdci/180hp,2017
Re: REMOTE START
Post by panchevks »
Does anyone know why the auxiliary heater is not starting when remote start the car? When I start driving it starts after 1 minute.
Cagdas
Vehicle: Ford Mondeo 1.6 TDI
Re: REMOTE START
Post by Cagdas »
Crusader wrote: Sat Mar 02, 2024 11:11 am hi everyone,
i have fiesta mk8 1.0 auto keyless entry
i did
BCM module- configuration parameters
• Remote start - enable
Hood Switch enable
IPC module - configuration parameters
Hood switch enable
• Remote start - climate settings- enable
i have all 3 keys working but my problem is HOOD AJAR LIGHT WARNING . i dont have hood ajar sensor
remote start one beep problem
https://www.youtube.com/watch?v=scds5mI ... el=WoneOne
i have same problem any idea how can i fix hood ajar light warning
Short-circuit the idle uranium leads.
https://youtube.com/shorts/uIQtbx-Xg64? ... m4aFvnaa44
Crusader
Vehicle: Puma ST Line X MHEV 155
Re: REMOTE START
Post by Crusader »
Cagdas wrote: Sun Jun 29, 2025 12:11 pm
i did
Hood Switch enable
Hood switch enable
It's been a long time since I solved the problem
LongingIngernot
Vehicle: 2017 Ford Kuga Diesel 2.0 150 HP PowerShift
Re: REMOTE START
Post by LongingIngernot »
LongingIngernot wrote: Sun Jan 05, 2025 10:10 am Hello! I am trying to enable Remote Start on my 2017 Kuga 2.0 Diesel Powershift. I have enabled it in BCM, IPC, and RFA. When trying to remote start, it tries to start but fails, logging DTC P027C in PCM. I have spoken to someone in Russia, and apparently, I need to edit the Fuel pump type. He said it could be done with UCDS. Can it also be done with Forscan? Could someone help me?
Finally did it!! :mrgreen:
Remember: If there is will, there is way and the sky is the limit! :D
Cagdas
Re: REMOTE START
Post by Cagdas »
Crusader wrote: Wed Jul 02, 2025 7:50 pm
i did
Hood Switch enable
Hood switch enable
I start the car remotely and get in. I press the start button and the screen says "See the service manual." When I start it normally, no warning appears.
Has this happened to you too?
Crusader
Re: REMOTE START
Post by Crusader »
Cagdas wrote: Thu Jul 10, 2025 4:12 pm
Yes, cause you don't have hood sensor.
Cagdas
Re: REMOTE START
Post by Cagdas »
Crusader wrote: Sat Jul 19, 2025 5:31 pm
PCM P166A:00-AE additional security system activation communication error
marpi82
Vehicle: S-MAX 2.0 TDCi/179PS, AWD, PowerShift 2016
Re: REMOTE START
Post by marpi82 »
fordsmax471 wrote: Fri May 22, 2020 12:18 pm • if the new key does not work immediately then change RTM module AsBuilt value 751-01-01 x2xx xxxx
Can anyone tell me what does this change in the RTM module exactly do?
Re: REMOTE START
I don’t quite remember anymore, but I think it was related to 433 or 434 MHz. If your key has the same frequency as the original, then you don’t need to change the values.
My Chinese key works without me having to change the value, but another key needed a value change on my friend’s car.
