REMOTE START
sanglt
Vehicle: Ford Mondeo Trend 2018
Re: REMOTE START
Post by sanglt »
From what I research:
Most cars built after 06/2017 have the Customer Spare Key Programming bit disabled and you will need to pay a visit to your dealer to add it to the car.
Can you check your REPLACING A LOST KEY OR REMOTE CONTROL from your manual, if it look like mine then the only option is pay a visit to your dealer.
misiak
Vehicle: Ford S-MAX 2016
Re: REMOTE START
Post by misiak »
fordsmax471 wrote: Sat May 02, 2020 5:11 pm look it's
but I didn't change anything from this RTM module
2 original keys and one remote start key are working very good ;)
https://www.youtube.com/watch?v=k76ESOMS5z0
Hi fordmax, I’m litle bit confused. Do all three keys works forw remote opening and keyless starting or only the new 3rd key and the other two have to be placed into a slot? I would really appretiate if all 3 keys works as normal with an advantage of 3rd key to remotelly start the engine. I don’t understand why those 2 original keys stop working after programming. Is this possible? I have smax mk2 2016 btw.
Re: REMOTE START
misiak wrote: Sat Aug 15, 2020 10:59 pm
Hi
Yes all three keys (2 old original and 1 new key to remote start) forw remote opening and keyless starting.
because I did not make any changes to the RTM module.
if a new key not work , you will need to make a change to the RTM module.
but then the old 2 original keys will no work, except for the spare slot.
misiak
Re: REMOTE START
Post by misiak »
Thank you very much for reply. What key for remote start do you have? Could you send me a link? It woul be great if two original smax keys works together with new remote one key. For what I’ve understood from that Polish video is that those two original keys are not working after pairing new key for remote start but I don’t understand why.
My two original keys are DS7T-15K601-DD and was thinking about DS7T-15K601-EF
sanglt
Re: REMOTE START
Post by sanglt »
I can confirm that the programming is successful on my Mondeo Mk5 2018. Just follow the guide, except the last step is Press & Hold the Start/Stop button until IPC popup message key learn successful. I can learn 2 new keys.
Remote start is working perfect for 2 keys too.
misiak
Re: REMOTE START
Post by misiak »
That’s great, what is the ID of your original keys and which ones have you bought for remote start? Could you send me a link? Thank you.
sanglt
Re: REMOTE START
Post by sanglt »
My origin key id is: HS7T-15K601-DC, and I get the new key id HS7T-15K601-ED
List of working is I get is from mondeo-mk5.de, so any keys have Long-distance start and 433MHz will work
WhatsApp Image 2020-08-10 at 9.41.27 PM.jpeg (132.58 KiB) Viewed 5663 times
misiak
Re: REMOTE START
Post by misiak »
Thanks for table. Seems frequency in that table is not correct as these keys are more to 434Mhz
DC is basically same as DD of mine. So ED could work for me as well, where did you get it from ?
Would you be so kind and take a photo of those 3 keys nect tomeaxh other? Very appreciated. Thanks.
It’s this one? https://www.cnautokeys.com/cn018093-ori ... p0111.html
I can see that part with physical key is missing, it’s delicered withour that bottom cap? It looks pretty ugly :)
sanglt
Re: REMOTE START
Post by sanglt »
misiak wrote: Tue Aug 18, 2020 8:08 am Thanks for table. Seems frequency in that table is not correct as these keys are more to 434Mhz
I have sent you an PM. There website doesn't have the OEM option for this key.
misiak
Re: REMOTE START
Post by misiak »
Thanks, sent you a PM as well. I'm really confused with these keys :)
