OBDLink® EX
troby
Vehicle: Focus 2008
Re: OBDLink® EX
Post by troby »
Ecmbuster wrote: Fri Jul 09, 2021 6:30 pm
troby wrote: Fri Jul 09, 2021 5:24 pm When I use Forscan everything works well but when I'd like to connection ELMconfig 0.2.17c I get error responds message.
As (V)CP and FTDI D2XX method also get the same "Incorrect response from adapter to request "ST I": STN2230 v5.6.5.
The ELMconfig is dated software and never kept up to the new interfaces.
This link offers what should be used.
https://fordcom.de/elm327/
The STN firmware is very different than the standard ELM327 device.
If you want ELMconfig to work, purchase the BAFX v1.4 and add the switch inside.
Thank you very much. Sad to hear that, I bought exactly for that reason this OBDLink EX. I already have the cheep ELM327 tools but that is too slow as the program sad to writing the PCM modul.
Re: OBDLink® EX
You answered your own question as to speed.
Don't change anything with the OBDLink EX, leave the drivers and firmware intact.
I have the BAFX and happy with it, the problem with ELMconfig is that it is slow to begin with.
You can try other USB cables that support FTDI D2xx drivers and also ask the ELMconfig forum users of what the best option is.
Faisje
Vehicle: Ford mondeo, 1.6 ecoboost / 160pk, 2011
Re: OBDLink® EX
Post by Faisje »
does stn2231 EXIST? here is my log from my brand new obd ex link from original site....
00:00:00.002: STN Firmware Updater v1.6.4 started.
00:00:07.854: Connecting to device...
00:00:08.286: Connection successfull.
00:00:08.604: Bootloader Version: 3.8
00:00:08.604: Device: OBDLink EX
00:00:08.604: HW Revision: 2.2
00:00:08.604: Serial Number: 10077957
00:00:08.604: Valid firmware present.
00:00:08.614: Selected firmware file is for a different device. Update aborted.
After starting forscan it says >> OBDLINK EX R2.2.1 STN2231 V5.6.19 (ELM327 v1.4b) The fuck is happening here? Is this fake or what. I ordered from original site....
Vehicle: *** Ford ***
Re: OBDLink® EX
Post by f-wolf »
Faisje wrote: Wed Dec 01, 2021 4:20 pm does stn2231 EXIST? here is my log from my brand new obd ex link from original site....
Did you get the update from here ??
https://www.scantool.net/scantool/downl ... bdlink_ex/
FIRMWARE UPDATES FOR OBDLINK EX
Here you will find short summaries of changes between the different firmware revisions. Developers should read the detailed changelog found inside the respective update archive.
To install an update via a Windows PC, download and extract the archive, then run StnFirmwareUpdater.exe
- For best results, set the Baud Rate to 115200
Faisje
Re: OBDLink® EX
Post by Faisje »
f-wolf wrote: Wed Dec 01, 2021 8:37 pm
Hello I did all that. OBDlink support told me they released a new version last week with newer HW revision and stn2231 chip. Due to shipping problems worldwide forscan didn't received their new version yet.
scorpionul22
Vehicle: Ford Focus MK3 RS
Re: OBDLink® EX
Post by scorpionul22 »
https://www.scantool.net/scantool/downl ... yReset.exe
OBDLink USB Factory Reset Tool
Scans for all OBDLink EX or OBDLink SX devices and performs a factory reset
VladTS
Vehicle: Ford Fiesta, sedan, 1.6, 2016
Re: OBDLink® EX
Post by VladTS »
Hello. I have Obdlink EX, bought on the official site. Forscan recognizes that this cable is not safe for calibration updates... Can someone help?
Here are my settings
Firmware is already the latest (as I clearly understand), cuz I got an error while updating in STN Firmware
Code: Select all
00:00:00.001: STN Firmware Updater v1.6.4 started.
00:00:02.758: Connecting to device...
00:00:03.086: Connection successfull.
00:00:03.399: Bootloader Version: 3.8
00:00:03.399: Device: OBDLink EX
00:00:03.399: HW Revision: 2.2
00:00:03.399: Serial Number: 10059963
00:00:03.399: Valid firmware present.
00:00:03.408: Selected firmware file is for a different device. Update aborted.
Adapter: OBDLink EX r2.2.1 STN2231 v5.6.19 (ELM327 v1.4b)
Forscan 2.4.4 beta
CDM212364
Settings in Windows
MTLEADER
Vehicle: 2000 CVPI, K-5 Blazer project,Corvair Monza pro,Mazda Rx7
Re: OBDLink® EX
Post by MTLEADER »
Ok so what is up with this connector does it work or no ? I cannot get mine to work on my car but that I think is due to my OBD2 port having a problem I tested pins 6 and 14 and get a resistance of 120 ohms so something is bad. Just need to know if this unit is going to work or if I just need to get a new one from someplace.
2000 CVPI,K-5 Blazer,Corvair Monza,Mazda Rx7,Toyota Pickup,Ford Pinto Wagon , Honda 3 wheelers (90cc,few 110cc,185cc,200m,250R pre85 Roundtubeframe,Custom Honda750 SuperSportStreet vert to 3-wheeler) SEND ME PRIVATE MESSAGE FOR INFO ON PROJECTS LISTED
VladTS
Re: OBDLink® EX
Post by VladTS »
MTLEADER wrote: Thu Jan 27, 2022 4:17 am Ok so what is up with this connector does it work or no ? I cannot get mine to work on my car but that I think is due to my OBD2 port having a problem I tested pins 6 and 14 and get a resistance of 120 ohms so something is bad. Just need to know if this unit is going to work or if I just need to get a new one from someplace.
It is working but slow, and forscan notify, that adapter has low speed and is not recommended to use for calibration update.
I updated IPC with 16mb for 3 hrs it was terrible...
MTLEADER
Re: OBDLink® EX
Post by MTLEADER »
This is messed up I bought this reader because it said best one for the program here on forscan site. Now it isn't so good lol. One other question this unit does it switch on both sides of the CAN network?
