REMOTE START
Posted: Tue Dec 17, 2019 6:19 pm
Hi !
Remote start the car ( Ford S-Max 2.0 TDCi 2017 PowerShift )
4Button Remote smart Key 433 or 434 MHZ DS7T-15K601-EF (please see ford etis )
guide for Ford S-Max mk2
To activate Remote Start, first you need a new key fob with start button (part # DS7T-15K601-EF for S-Max mk2 with 434 MHz).
Note ! remove the metal blanks from the keys, the car doors are closed and the handbrake deactivated.
Programming keys
Place the first programmed key in the backup slot. Press the START / STOP button.
Within 5 seconds, place the second programmed passive key in the backup slot, then press the START / STOP button.
Within 5 seconds, place the unprogrammed passive key in the backup slot and press the START / STOP button.
Congratulations on your new key being programmed !!!
Now use Forscan to change the asbuilt-data
BCM module- configuration parameters
• Remote start - enable
IPC module - configuration parameters
• Remote start - climate settings- enable
• Remote start - front seat- enable (optional)
• Remote start - rear defrost – enable (optional)
• Remote start - steering feel – enable (optional)
some guides recommend
RTM module - configuration parameters
• don't change anything
( old keys can also be used in the future )
Programming keys
