pats programming mondeo
rsharry
Vehicle: mondeo mk3 2.5 v6
Post by rsharry »
Hope you understand my not so excellent english
I have an ford mondeo mk3 2.5
Want to try it with an st200 ecu.
I havent got any keys for that st200 ecu.
Is it possible to programm the st200 ecu to use my normal keys from my mondeo? Or do i programm the keys on the st200 ecu so that i cant use then for my normal 2.5 v6 ecu?
fred08155
Re: pats programming mondeo
Post by fred08155 »
At the moment it is not possible to program keys with Forscan without a key that is already programmed in the PATS.
I am not sure if this is a restriction of the program or wanted to do not support car thiefs.
Does the ST200 use the same transponders as the mondeo mk3 (4D60 crypto transponder)?
rsharry wrote:Is it possible to programm the st200 ecu to use my normal keys from my mondeo? Or do i programm the keys on the st200 ecu so that i cant use then for my normal 2.5 v6 ecu?
Mondeo 3 has the same PATS function and as far as we know standard mondeo 3 keys (with blue transponder insert). Please correct us if we are wrong.
Advice how to program it using FORScan (in your case) sent by PM.
rsharry wrote:I am not sure if this is a restriction of the program or wanted to do not support car thiefs.
Right, this is some kind of anti-theft protection. However since v2.2.4 it is possible to program PATS in the situation described above, if user has 2 blank keys.
