I have a Ford Galaxy 2.2. Ghia and while it works pretty well, it does suffer from a (what seems to be quite common with this model) engine hesititation/stutter between 1500 and 2000 revs. It's not a huge problem but is annoying!
What I'd like to do is to monitor the MAF sensor and injectors with FORScan as I drive, so that I can get an idea of what is occurring - my question is, what (range of) readings would be recognised as being acceptable/within tolerance for both the MAF and the injectors? Is there any partiular behaviour I should be looking out for, which may indicate a problem?
Are there other obvious PIDs I should monitor?
Any ideas or guidance will be very welcome.
Cheers,
Ebo.
Recording MAF and Injector Readings
Re: Recording MAF and Injector Readings
Looking for the same reference information in the internet I found that in most cars there usually exists specific PID called MAF_DESIRED which shows values PCM expects to see from MAF in current driving conditions.
You may compare these two PIDs and see whether they are similar. As I understand DESIRED value should be close to actual readings or less for 5-15%. Typical problem with MAF being lower than MAF_DESIRED will be clearly seen.
For injectors there may also be similar PID.
Thanks Hostj - I'll try this and see how I get in.
Ebo.
Ebo.
