OIL LIFE menu Focus MK4 (2019) 1.5 Ecoblue
fmmb
Vehicle: Ford Fiesta
Post by fmmb »
Can anyone advise me how to turn on OIL life MENU on Focus MK4 (2019) 1.5 Ecoblue using Forscan? Thanks!
mschumiv
Vehicle: Ford Focus MK4 1.5L 88kw diesel 2019
Re: OIL LIFE menu Focus MK4 (2019) 1.5 Ecoblue
Post by mschumiv »
Easy. Go to IPC direct config menu, disable Oil change reminder and enable Oil Minder Distance/Time
fmmb
Post by fmmb »
Its working! Thank you! :shock:
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Post by RSWRC »
Does it work for you?
I will try the 2.0 Ecoblue on my Ford S-Max 2019! ;)
RSWRC
Post by RSWRC »
The above procedure does not work on the 2019 Ford S-Max on IPC.
When I disable the oil change from the settings in IPC, the oil life box disappears.
When I turn it back on and also turn on the Distance / Time Oil Minder, despite this, the life % of the oil does not show... :/ ;)
mschumiv
Post by mschumiv »
You disable one and enable the other
RSWRC
Post by RSWRC »
mschumiv wrote: Sat Jul 30, 2022 9:31 am You disable one and enable the other
I did it as you write.
But the oil life tab disappears.
This is a Ford S-Max
stefcio007
Vehicle: Ford Focus 2020.25 Wagon
Post by stefcio007 »
When I disable oil life minder and enable the time/distance I get the display, but both both are always empty "--".
When I set it back my normal oil life comes back and shows % only which is the default for my car.
Focus 2020.25 ST-Line 1.5L Wagon
