Disable brake pad warning message
vanduara37
Vehicle: Transit custom 2014
Post by vanduara37 »
2014 Transit custom, have bypassed all 4 sensors by soldering wires together, "Brake pad warning message" still on.
Forscan gives option to enable or disable brake pad warning message but when selecting to disable it I still get warning message in dash. Any solution available ?
Keithmac
Re: Disable brake pad warning message
Post by Keithmac »
As far as I can see the brake pad sensor grounds itself to the brake disk when pads are low so all the sensor wires should be open line / disconnected?.
WALK3R
Vehicle: I would never own a ford
Post by WALK3R »
Keithmac wrote: Sat Mar 19, 2022 9:01 pm As far as I can see the brake pad sensor grounds itself to the brake disk when pads are low so all the sensor wires should be open line / disconnected?.
They should be closed loop. they open loop once the pad minimum thickness is reached... :shock:
WALK3R
Post by WALK3R »
vanduara37 wrote: Sat Mar 19, 2022 7:28 pm 2014 Transit custom, have bypassed all 4 sensors by soldering wires together, "Brake pad warning message" still on.
Wonder if a cable is damaged reporting open loop? check to see if the sense wire is good and at a reasonable ohm value
vanduara37
Screenshot (5).png (99.64 KiB) Viewed 6286 times
Do you think if i connect bl/gn wire from BCM to earth it will fool the BCM to think the circuit is complete ?
Keithmac
Post by Keithmac »
Worth a try, if that doesn't work then it could be internal BCM fault (faulty pull-up resistor).
vanduara37
Well it didnae work. The wiring diagram is nothing like the actual wiring on the van. :roll:
Jape324
Vehicle: Ford Transit connect 1,6 tddi 95h 2015
Post by Jape324 »
Hi.
I have the same problem. Can I use forscan to completely disable monitoring :roll: ? How to do this? Thanks in advance for the answers
Camper Rich
Vehicle: transit custom 2.0 130ps 2017
Post by Camper Rich »
Hi it's in IPC Module config .. Ceramic brake pad wear indicator ... Disable :D
