Ford IDS
kkehoe8501
- Vehicle: Mustang, Coyote 5.0/2017
Ford IDS
Very quick and simple question, will the OBD Link EX work with Ford IDS? If so which option should I select, or what adapter is best for my vehicle, 2017 Ford Mustang GT Manual
Re: Ford IDS
IDS Will only work with a Ford VCM2 adapter! Period.kkehoe8501 wrote: Wed May 10, 2023 2:28 am Very quick and simple question, will the OBD Link EX work with Ford IDS? If so which option should I select, or what adapter is best for my vehicle, 2017 Ford Mustang GT Manual
Re: Ford IDS
also works with vcx nano for ford and mazda
Re: Ford IDS
IDS works with VCM I, VCM II, VCM 3, VCMM and VMM devices.
Clones are limited.
Clones are limited.
Re: Ford IDS
Ids only works with dedicated Ford hardware only.
FJRS which is the programming only software works on j2534 standard which looks like IDS.
FDRS works on j2534 standard also
