Unable to identify the vehicle
yeoman
Vehicle: 2012 lexus es 350
Post by yeoman »
Hi. Got 2012 Ford Taurus SHO tried connect it's asking me for STRATEGY code from pcm also it says "Unable to identify the vehicle". Connected the autel and reads the vin and everything. Any solutions will greatly appreciated.
oldtinfords
Re: Unable to identify the vehicle
Post by oldtinfords »
Enter the strategy code from the PCM as instructed
kryptto
Vehicle: Taurus SHO 3.5l twin turbo 2014
Post by kryptto »
* ECU Strategy: NOT FOUND
This is what the SCT TSWire shows - and why Forscan for Android says it cant communicate with the car.
I have the same issue - and put in the strategy code from a save picture I gave my tuner - he didnt block my ability to see it - I asked him - however even when I enter the correct strategy code - it wont accept it.
oldtinfords
kryptto wrote: Mon Feb 19, 2024 2:37 pm * ECU Strategy: NOT FOUND
If you have a saved profile, you can usually connect using this profile.
If you don't have a saved profile, reset to stock using the SCT. Connect to the car & save profile.
Reflash with the SCT & connect to the car using the saved profile.
