How to run FORScan on Windows computer with ARM CPU
The 3rd pary protection/licensing system used by FORScan doesn't work properly on Windows 10/11 laptops with ARM CPU. By default, FORScan cannot be ran on such computer (nothing happens when user clicks on the FORScan icon), or some weird error window is displayed:
So how to fix:
1. Right mouse click on the FORScan icon and select Properties in the popup menu:
2. In the window opened select Compatibility tab, then find and press the "Change emulation Settings" button there:
3. In the dialog opened select "Safe emulation":
4. Press OK to close the dialog, press Apply to close the parent window.
Thanks to George Humphrey who developed this guide.
twisterrescue
Vehicle: 2003escapeltd
Re: How to run FORScan on Windows computer with ARM CPU
Post by twisterrescue »
Thank you great info .can you please reset my beta tester extended lic. it quit working the other day ! twisterrescue
GHum7771
Vehicle: C-Max, gasoline/Hybrid, 188HP, 2018
Post by GHum7771 »
I’m glad I could help.
mrc1986
Vehicle: Ford Kuga, Transit Custom
Post by mrc1986 »
also if you are having issues with your vlinker usb drivers on windows 11 ARM
Use these drivers and the device will be able to connect, the ones vlinker give on their website are only for normal versions of windows and won't be recognised.
https://ftdichip.com/wp-content/uploads ... utable.zip
sragsdill
Vehicle: 2018 F150 Lariat 3.5L Ecoboost SCrew
Post by sragsdill »
I need help getting Forscan to open.
Using Windows 11 via VMWare Fusion on M3 Macbook.
Windows 11 is up to date.
Forscan V2.3.64 installed.
Emulation set to safe as recommended above.
The blue ring spins for a few seconds, then nothing.
oldtinfords
Post by oldtinfords »
sragsdill wrote: Fri Jan 17, 2025 5:40 pm I need help getting Forscan to open.
Uninstall, reboot & reinstall. Follow the instructions above before trying to run FORScan.
KazWolfe
Vehicle: 2021 Ford Explorer ST
Post by KazWolfe »
For anyone still having difficulty, try setting the application to use only a single core for emulation:
Screenshot 2025-01-21 at 09.11.31.png (123.76 KiB) Viewed 13000 times
I can report success with these settings on an M4 Max, macOS 15.1.1, VMWare Fusion 13.6.2, Windows 11 guest.
sragsdill
Post by sragsdill »
Thank you KazWolfe that did the trick!
found
Vehicle: F150 Lariat 3.5L EcoBoost 2018
Post by found »
Would appreciate if anyone who is running FORScan on a ARM Snapdragon processor could advise how their system is preforming.
Also if possible advise how stable it is and what FORscan test functions they use it if for.
Thanks in advance, I appreciate your time
BUGGIE_X
Vehicle: FORD Fusion, 2.0 AWD, Titanium, 2013
Post by BUGGIE_X »
Finally I found this, Thanks KazWolfe , now it's working again at my MacBook Pro running windows 11 pro thru parallels..... thanks..
