Hi guys trying to disable TPMS sensors in Ford Kuga 2016 2.0 Duratorq diesel.
Have done this in my Ford smax however the process on Forscan looks a bit different and I am struggling to piece it together.
I can't find any references to the TPMS system on ForScan I can only find TMS in the BCMii module config
Hoping TMS is not Temp Monitoring System
In the BCMii module there are a selection of various options but none to clear cut disable the system.
Any one done this previously any help would be appreciated
Attached are screenshots of Forscan
Ford Kuga TPMS Disbake
georgio39230
- Vehicle: KUGA 1.5 écoboost 2015 et fiesta 1.0 éconotic 2013
Re: Ford Kuga TPMS Disbake
Hi, I did this on my 2015 Kuga. Here are my modifications; I hope it's the same for you.
The images are not loading.
In engineer mode 2, in BCMII, you need to find: tire pressure monitoring system and change it to "not configured" instead of "TPMS FedReg EU".
Next, in the IPC, you need to find: indicators-Tire Pressure Monitor and change it to "disabled" instead of "enabled".
And still within IPC, you need to find: deflation detection system and change it to "Disabled" instead of "enabled"
Have a nice weekend
Salut, je l'ai fait sur mon KUGA de 2015.
Voilà mes modifications en espérant que c'est identique pour toi.
Les images ne se mettent pas.
En mode ingénieur 2, dans le BCMII, il faut trouver: système de surveillance de la pression gonflage des pneus et la changer en "not configured" à la place de " TPMS FedReg EU".
Ensuite dans l'IPC il faut trouver: indicators-Tire Pressure Monitor et changer en "disabled" à la place de "enabled"
Et dans IPC toujours, il faut trouver: système de détection de dégonflement et changer en "Disabled" à la place de "enabled"
Bon week-end.
Have a nice weekend
Bon week-end.
Please excuse my English language. I use google translate, thank you.
Thanks for that will have a look tomorrow and report back.
What you describe above is very similar to the SMax config maybe this Kuga has been modified in some way
I have tried to attach the file again
- Screenshot_20251225-105430.png (356.57 KiB) Viewed 650 times
- Screenshot_20251225-105435.png (502.49 KiB) Viewed 650 times
georgio39230
Il faut choisir BCMII central configuration (MAIN) pour modifier.
Thanks for that but when I try to get into the (Main) I get an error to say secondary boot loader not found
georgio39230
Hi, sorry I don't know how to help you any further. Is your license activated?
Salut, désolé je ne sais pas comment t'aider mieux. Ta license est bien activé?
Many thanks forall the replies,
FYI for anybody else looking forthis I managed to disable the TPMS by changing the following
Tire Pressure monitoring withintheIPC module
Cant upload screenshot.
Refer to other weblink for screenshot
https://www.fordownersclub.com/forums/t ... able-tpms/
