dan_uk wrote: Fri Mar 29, 2024 4:16 am Hi, please could somebody send me the as built data for my 2012 S Max 2.0 (163) powershift?
The VIN is WF0SXXGBWSCE45622
Motorcraft is just giving me blank results![]()
Thank you for your reply, unfortunately this file is the same as the file that Motorcraft has been giving me and doesn't seem to be containing any data
The link in #6 above, http://www.fordvehiclemods.com/
, has been changed to lead to a sales site.
Agree, I have not been able to find one and have reached out for some assistance. No luck . I have read somewhere, can't remember where that the 2023/2024 MachE is the same as the 2023/2024 Ford Escape PHEV ....I have only enabled Global Open /Close, but the close will not work...I used the BCM, PDM, DDM, APIM module configuration option as I can't find the bytes information for the As Built
Bcm AS-Built option
Hi all I hope this is in the right section .
I have a 2012 transit and when I connect there is no bcm as built option to click on .
There is for other modules just not bcm could this be because it has faults hence why I am changing the module ?
Tried a few version of forscan and I do have the licence version I'm just a bit worried about fitting the donor bcm if I can't write my vans data to it .
I do have all the data files downloaded already to go.
Many thanks
Many thanks
Re: Bcm AS-Built option
If you are the same smithy that posted over on the Face Book group,? then you have a Central configuration vehicle! Your image there (attached and it shows a very old FORScan version 2.3.25 Current is 2.3.64) shows a BCMii(Main) and an IPC(Backup) and in central configuration vehicle the majority of all configuration operations are conducted under engineering mode which will be in a drop down list at the top left of the BCMii configuration configuration screen! The IPC(Backup) will usually contain a backup under a similar drop down in the configuration dialog screen and can be used to extract the original configuration if the BCMii(main) is missing or corrupt!Smithy69 wrote: Tue Jan 21, 2025 3:15 pm Hi all I hope this is in the right section .
Many thanks
To access these, "High lite" the BCMii(Main) and click the "Play" button and a tab should appear called "Central Configuration and Opening that tab should open to a dialog with a Drop down arrow on "Normal" list in the top left corner and should open a couple of engineering mode options! IPC(Backup) is opened in a similar way
Opening these will open a list of engineering configurations! Configuration changes will require loading a Secondary Boot Loader(SBL) (similar to firmware loading in calibration file changes which requires FORScan 2.4.16) which will need to be downloaded from the internet the first time! FORScan may have the SBL this vehicle requires in a Paid license Database(a box opens and will ask for a file number and if you wish to download)!
See this topic for more on Central Configuration CC viewtopic.php?p=8036#p8036
- CCF_1.png (73.65 KiB) Viewed 7084 times
Many thanks for your help I will go and give this a try now .idi have latest version of forscan it's just i tried a few versions incase it was a bug .I also have licence ,sbl and the as built data from motocraft all ready to go .
I was just looking for the as built as in all the youtube videos I had watched . Thanks again
Hopefully this is the right place, currently assisting with a Focus MK4 with Sync 3.4 latest version.
As this is an ST Line we wanted to set the spash screen to ST Line which is an available option, however once selected and written nothing changes. So i tried Ford Performance to see if that works (works in my car) but again no changes. Any ideas why Sync 3.4 in the MK4 does not let you change the splash screen? I did get the clima button without any issues.
Hello Team,
Does anyone in our group have an As built decoding for the Ford Everest?
Thank you!
Thank you!
Can anyone tell me where I can find spreadsheet for 2025 Ford Transit Van Thanks
