matteotec
Vehicle: Puma 2020-, 1.0L EcoBoost
Post by matteotec »
dan_uk wrote: Fri Mar 29, 2024 4:16 am Hi, please could somebody send me the as built data for my 2012 S Max 2.0 (163) powershift?
The VIN is WF0SXXGBWSCE45622
Motorcraft is just giving me blank results :(
WF0SXXGBWSCE45622.rar
non se se puo servire ancora
(472 Bytes) Downloaded 306 times
dan_uk
Vehicle: S Max / 2.0TDI 163 / 2012
Post by dan_uk »
matteotec wrote: Sat Apr 06, 2024 8:56 pm
Thank you for your reply, unfortunately this file is the same as the file that Motorcraft has been giving me and doesn't seem to be containing any data
ABertram
Vehicle: F150, 4.6l, 2010
Post by ABertram »
The link in #6 above, http://www.fordvehiclemods.com/
, has been changed to lead to a sales site.
JaxPony
Vehicle: 2024 Escape Hybrid PHEV
Post by JaxPony »
Golfman454ss88 wrote: Sun Apr 15, 2018 3:21 pm I wish there was a spreadsheet for escapes.
Agree, I have not been able to find one and have reached out for some assistance. No luck . I have read somewhere, can't remember where that the 2023/2024 MachE is the same as the 2023/2024 Ford Escape PHEV ....I have only enabled Global Open /Close, but the close will not work...I used the BCM, PDM, DDM, APIM module configuration option as I can't find the bytes information for the As Built
Smithy69
Vehicle: Transit mk7 2.2 tdci 2007
Bcm AS-Built option
Post by Smithy69 »
Hi all I hope this is in the right section .
I have a 2012 transit and when I connect there is no bcm as built option to click on .
There is for other modules just not bcm could this be because it has faults hence why I am changing the module ?
Tried a few version of forscan and I do have the licence version I'm just a bit worried about fitting the donor bcm if I can't write my vans data to it .
I do have all the data files downloaded already to go.
Many thanks
Re: Bcm AS-Built option
Post by tractmec »
Smithy69 wrote: Tue Jan 21, 2025 3:15 pm Hi all I hope this is in the right section .
Many thanks
If you are the same smithy that posted over on the Face Book group,? then you have a Central configuration vehicle! Your image there (attached and it shows a very old FORScan version 2.3.25 Current is 2.3.64) shows a BCMii(Main) and an IPC(Backup) and in central configuration vehicle the majority of all configuration operations are conducted under engineering mode which will be in a drop down list at the top left of the BCMii configuration configuration screen! The IPC(Backup) will usually contain a backup under a similar drop down in the configuration dialog screen and can be used to extract the original configuration if the BCMii(main) is missing or corrupt!
To access these, "High lite" the BCMii(Main) and click the "Play" button and a tab should appear called "Central Configuration and Opening that tab should open to a dialog with a Drop down arrow on "Normal" list in the top left corner and should open a couple of engineering mode options! IPC(Backup) is opened in a similar way
Opening these will open a list of engineering configurations! Configuration changes will require loading a Secondary Boot Loader(SBL) (similar to firmware loading in calibration file changes which requires FORScan 2.4.16) which will need to be downloaded from the internet the first time! FORScan may have the SBL this vehicle requires in a Paid license Database(a box opens and will ask for a file number and if you wish to download)!
See this topic for more on Central Configuration CC viewtopic.php?p=8036#p8036
Smithy69
Post by Smithy69 »
Many thanks for your help I will go and give this a try now .idi have latest version of forscan it's just i tried a few versions incase it was a bug .I also have licence ,sbl and the as built data from motocraft all ready to go .
I was just looking for the as built as in all the youtube videos I had watched . Thanks again
easyq
Vehicle: Ford Focus First Ediotion MK3.5 2015
Post by easyq »
Hopefully this is the right place, currently assisting with a Focus MK4 with Sync 3.4 latest version.
As this is an ST Line we wanted to set the spash screen to ST Line which is an available option, however once selected and written nothing changes. So i tried Ford Performance to see if that works (works in my car) but again no changes. Any ideas why Sync 3.4 in the MK4 does not let you change the splash screen? I did get the clima button without any issues.
hanz
Vehicle: Ford Everest 2021
Post by hanz »
Hello Team,
Does anyone in our group have an As built decoding for the Ford Everest?
Thank you!
Joe Hofer
Vehicle: Ford F250-F350 Transit Ford 350
Post by Joe Hofer »
Can anyone tell me where I can find spreadsheet for 2025 Ford Transit Van Thanks
