Help! !! !! v2.4.0.test202000121 refreshes BCM crashes
lxlxj
Vehicle: F150 3.5 2017
Post by lxlxj »
ESL27, the firmware update is automatic, everything is normal during the update, after the update, the car does not respond after opening the key, just like the power failure, now the OBD is no longer connected
Current status video
https://drive.google.com/file/d/1OH1Vu9 ... sp=sharing
https://youtu.be/H6-Yfd6xD-o
lxlxj
Re: Help! !! !! v2.4.0.test202000121 refreshes BCM crashes
Post by lxlxj »
Using ELS27 to update the firmware, now the car is like a power outage
if you used the original OBD adapter, this is not the cause of the malfunction
please describe the software update in more detail
could be a video of the current situation
lxlxj
Post by lxlxj »
switch ignition on and connect the OBD adapter
can you get the connection and what the error codes are and so on.
lxlxj
Post by lxlxj »
ok
we check if the adapter and software are okay
connect the adapter to the computer and run FORScan without the car
if you still have an old profile then press "YES"
if the adapter and software are in ok you should get such a picture
then check all fuses
https://www.autogenius.info/ford-f-150- ... x-diagram/
and also measure the OBD connector on the multimeter
lxlxj
Post by lxlxj »
Thank you very much, try it tomorrow, but the configuration file has been deleted. I still have a 2019 F150 that can read the configuration file. Can it be used?
