ipc module update error
albix76
Vehicle: c max 1.5 tdci 120 cv 2016
Post by albix76 »
good morning everyone, I tried to update my ipc module, only that during the procedure it got stuck, now I find myself with the instrument panel completely off, I tried to redo the operation, but I can no longer proceed, the last attempt stopped me at 85%. can you help me why I can't finish the operation? thank you sorry I have a Ford cmax 2016
Re: ipc module update error
which adapter you are using :?:
whether you are using a battery charger :?:
whether you can connect to the IPC :?:
vehicle previous backup profile :?:
which date FORScan 2.4.0 version you are using :?:
rbkteam
Vehicle: Ford Transit Custom MY20 130hp
Post by rbkteam »
we're a lot of people with the same isue in my19 and my20... IPC module is "untouchable" for now.
Waiting a Forscan update or some other solution for this.
albix76
Post by albix76 »
i have an els27 cable, the machine is connected to a charger, the ipc module i see it, but when i try to write the firmware it freezes, the last time at 83%, i am using forscan 2.4 20200120 now, I find myself with the instrument panel completely off
gianni_66
Vehicle: C-MAX II 12/2010
Post by gianni_66 »
I have updated ipc with forscan 20200121 and obdlink ex
gianni_66 wrote: Mon Apr 13, 2020 2:47 pm I have updated ipc with forscan 20200121 and obdlink ex
albix76
Post by albix76 »
I wanted to thank fordsmax471 for the assistance, thanks to him and his experience I was able to restore my IPC module which during the update had crashed. thanks for everything :)
gianni_66
Post by gianni_66 »
albix76 wrote: Tue Apr 14, 2020 1:36 pm I wanted to thank fordsmax471 for the assistance, thanks to him and his experience I was able to restore my IPC module which during the update had crashed. thanks for everything :)
explain how you solved it, it can be useful to others
gianni_66 wrote: Tue Apr 14, 2020 2:11 pm
Yes, sure ;)
written by google translation :geek:
:shock: IF THE MODULE UPDATE FAILED :!:
note :!: who does not use the battery charger and does not make a backup cannot help
but here he is:
:arrow: the adapter was els27v3 STN1170 Ver3.3.1, we wanted to update it latest Version 5.0.0 release date: January 8, 2020 but it failed (don't know why yet) :( but this is a separate issue.
:arrow: we used FORScan software 2.4.0 date 20200114
:arrow: older car profile which showed a dead IPC module ( so we always make backups 8-) )
:arrow: car profile file location C:\Users\AppData\Roaming\FORScan\vehicles
:arrow: the same module software that was originally in the figure no.3
:arrow: and settings FORCE PROGRAM in the figure no.4
:arrow: we adjusted the forscan connection settings all auto and auto-increase
:arrow: we setup the OBD adapter baud rate 38400bps and FDTi dariver settings latency timer =1
:arrow: battery charger 6amps ( good is 8-12amps )
:arrow: after a successful upgrade load As Built original *AB factory configuration (download for Motorcraft site by VIN) write All (all blocks!) to the module. (optional-because the latest version does it automatically)
START .png (236.32 KiB) Viewed 7777 times
gianni_66
Post by gianni_66 »
fordsmax471 wrote: Tue Apr 14, 2020 2:17 pm
Yes, sure ;)
if the module update failed :!:
but here he is:
:arrow: older car profile ( so we always make backups 8-) )
:arrow: we adjusted the forscan connection settings all auto and automatic baud rate speed
it was 2 days all does not immediately remember :D
very good 8-)
