Thanks a lot for the answer, one more question please, how can I deactivate "System Off Battery Saver" from sync ? thank youfordsmax471 wrote: Sat Sep 19, 2020 12:50 pm if this still does not work, install the files separately
1.
...21..
...19..
...82..
do not turn the ignition off
2.
...21..
...24..
3.
...21..
...81..
ReFlash dead Module with Forscan 2.40???
- ddg71
- Vehicle: Ford Mondeo 2.0 TDCI Powershift, 180 HP, mk5, 2016
Re: ReFlash dead Module with Forscan 2.40???
Forscan 2.4.2 , Obdlink EX
- ddg71
I finally managed to separate modules I upload as you said, thank you very muchfordsmax471 wrote: Sat Sep 19, 2020 12:50 pm if this still does not work, install the files separately
1.
...21..
...19..
...82..
2.
...21..
...24..
3.
...21..
...81..
How do you install the files separately?
you select custom at the top and then only the secondary boot loader (sbl) and the file you want to write separately. Leave all the other options blank.
Is it too much trouble to ask for a screenshot if you can. Thanks.Snowball wrote: Mon Sep 28, 2020 10:38 pm you select custom at the top and then only the secondary boot loader (sbl) and the file you want to write separately. Leave all the other options blank.
- ddg71
exact !!!Snowball wrote: Mon Sep 28, 2020 10:38 pm you select custom at the top and then only the secondary boot loader (sbl) and the file you want to write separately. Leave all the other options blank.
rmorriso86
- Vehicle: 2016 Ford, 2.0 ecoboost
so i have the same problem with the ipma it upload them all then fails on the last one tried doing just the last one as a custom still a no go goes to 97% then shows a failure? Any other ideas? running 2.4.3 test20200917
rmorriso86
this is a image
- Screenshot 2020-11-12 113849.jpg (218.65 KiB) Viewed 3756 times
- fordsmax471
