Adapter ELS27 Stn Firmware update
Re: Adapter ELS27 Stn Firmware update
:arrow: Els27 v4.0 Chip STN2120
Latest Version 5.6.1
Release Date: September 18, 2020
https://www.scantool.net/downloads/updates/stn2120/
This major release fixed a few bugs:
Fixed 7Fxx78 message being counted when using STPTO 0
Fixed STSLU, STSLVL, and STSLX not working
This release added a few new features and changes:
Added command to change CAN consecutive and flow control frame reception timeouts
Added command to specify additional STmin delay
Added support for 4 byte header to ATSH
Removed CAN deaf time after sending a CAN message
See stn2120-changelog.txt inside the archive for detailed descriptions of the changes.
scorpionul22
Vehicle: Ford Focus MK3 RS
Post by scorpionul22 »
v5.6.5 - 2020/10/14
- BUG: Fixed ISO protocol detection failure
v5.6.4 - 2020/10/06
- BUG: Fixed a BUFFER FULL caused by the CAN RX buffer getting filled while waiting for a FC frame during a multi-frame transmission
Only ELS27 V 4 chip stn2120
for ELS27 V3 corect firmware is 4.1.1
tunademir45
Vehicle: Ford Kuga Mk3 St Line 2020 model 1.5 ecoblue otomatik
Post by tunademir45 »
Version 4.1.1 was faster and more stable. I upgraded to version 5.6.5 very slow and gave errors. How can I revert to version 4.1.1? help please
tunademir45
amami wrote: Sun May 03, 2020 2:08 pm
vondr wrote: Fri May 01, 2020 6:11 pm Try this
-download ELS27Baudrate from els27.ru/files/ELS27_Baudrate.zip and run it
-open adapter port and set baudrate 115200
-run stnfinder and check if adapter is found, then try Forscan
-set baudrate to 500000 and test Forscan (stnfinder not work on this baudrate)
The adapter is not found.
I need firmware 4.1.1 for Stn2120 for downgrade.
If anybody hase it, please post it.
Could you find version 4.1.1? I need version 4.1.1 too. can you help me
scorpionul22
what version is els27?
tunademir45
scorpionul22 wrote: Tue Nov 03, 2020 3:45 pm what version is els27?
I need 4.1.1 version for els27 v4 adapter
tunademir45 wrote: Tue Nov 03, 2020 3:57 pm
before changing the stn2120 software i recommend checking the prolific windows driver
tunademir45
fordsmax471 wrote: Tue Nov 03, 2020 4:45 pm
In version 4 1.1, my adapter was doing very fast. Maybe 10 slips slower in version 5.6.5 now. I want to go back to the old version again. Or how do I make it fast as before?
yes the version that works fast is unfortunately full of bugs :D
what are the settings for your obd adapter and forscan :?:
