you mean's flash don't use stop buses all ?
the key on stage2 alltime ?
2014 explorer ipc flash faild
- fordsmax471
Re: 2014 explorer ipc flash faild
first testfbstn wrote: Mon Oct 19, 2020 5:36 pm you mean's flash don't use stop buses all ?
first programming---> SBL: bootloader and Strat: ET4T-14C026-BL
and
second reprogramming---> SBL: bootloader and Calib: ET4T-14C088-BL
if it fails
second test
and
- fordsmax471
the key on stage2 alltime ? yes
we are waiting for the results
failed on load block13/26
is it problem ons use 2.4.3test20200920 ,who can give other versions ?
- fordsmax471
- fordsmax471
PMfbstn wrote: Tue Oct 20, 2020 4:39 am is it problem ons use 2.4.3test20200920 ,who can give other versions ?
go to 4S store use IDS fail !
reflash with UCDS force flash dead module be OK !!
THANK YOU ! fordsmax471 !
everybody Be careful when flash IPC !
