P0A7C criteria PCM parameter / wrench light?
Jasonisawesome
Vehicle: 2009 ford escape hybrid
Re: P0A7C criteria PCM parameter / wrench light?
Post by Jasonisawesome »
My live readings are all within it the ranges.
The wrench light will come on and trigger within driving 3 miles at 70 mph at 45°F
tim0574
Vehicle: 2011 Ford Escape Hybrid
Post by tim0574 »
How about a sweet hood scoop mod to channel some air strategically? :D
Any chance the trans cooler lines in the radiator are picking up the engine coolant heat since that's running in the 180s on highway drives?
Edit: I looked at the radiator parts breakdown & previous messages to realize the radiator runs the 2 coolant systems. Nothing for the trans fluid like a typical vehicle.
tim0574
Post by tim0574 »
Outside temp didn't dissuade the wrench light today. Outside temp near zero today & light popped within 5 minutes of highway driving.
Jasonisawesome
tim0574 wrote: Sat Feb 06, 2021 9:45 pm Outside temp didn't dissuade the wrench light today. Outside temp near zero today & light popped within 5 minutes of highway driving.
Mine as well. I took mine in to tHe dealership and had them update the PCM. didn't help
Jrpavv
Vehicle: Fusion Hybrid 2011
Post by Jrpavv »
How much did your dealer charge for the tab?
Jrpavv
Post by Jrpavv »
Does anyone have the procedure for bleeding the secondary coolant system? I used to have it, but can't find it. I know you have to loosen the 12 mm bolt on the inverter, but don't remember if you have to have the engine running or not.
Jasonisawesome
Jrpavv wrote: Fri May 21, 2021 5:31 pm How much did your dealer charge for the tab?
They charged me $100 out the door.
Jrpavv wrote: Fri May 21, 2021 5:34 pm Does anyone have the procedure for bleeding the secondary coolant system? I used to have it, but can't find it. I know you have to loosen the 12 mm bolt on the inverter, but don't remember if you have to have the engine running or not.
You'll need the motor running to get the coolant to push the air pockets out
ahernandez15
Vehicle: ford fusion hybrid 2010
Post by ahernandez15 »
So 2021 any solutions to this lol??
wr400f250
Vehicle: 2010 Fusion Hybrid, 2009 Escape Hybrid, 2003 Explorer 4.6
Post by wr400f250 »
It's one of 3 things for sure. Probably a combination of 1 and 2.
1. Air in coolant. Only thing I haven't tried is a vacuum fill.
2. Transmission fluid getting too hot. 2013+ Fusion hybrids added a small transmission cooler.... suspicious...
3. Faulty inverters (unlikely, and let's hope not)
Even though I don't own the car anymore, I still have access to it. I've been brainstorming a transmission cooler idea that I'll give a shot as soon as I get some time to do it. Money's been tight so it's been pretty low on my priorities list.
ahernandez15
It's just crazy how city driving. At much higher temps it doesn't trigger that light. Highway driving at 90 plus weather will trigger in 10 mins.
At this point from what I see I doubt even dealer can fix issue
