Installing USB drivers for OBDLink EX
obdlink
Vehicle: 2015 Ford Expedition
Post by obdlink »
Most of the time, OBDLink EX installation is a smooth process: the USB drivers should install automatically as soon as you plug it in.
Unfortunately, certain laptop models feature a non-compliant USB 3.0 controller which sometimes causes problems for our customers.
If you receive "USB not recognized" or similar error messages, try one of the following solutions:
1. Plug OBDLink into a different USB port
2. Connect OBDLink via a USB 2.0 hub
3. Manually install the FTDI USB drivers
If none of the above solutions work, please contact OBDLink Support.
Kind regards,
OBDLink Support Team
Signalsguy
Vehicle: 2013 Ford F150 3.5L, V-6 Turbo
Re: Installing USB drivers for OBDLink EX
Post by Signalsguy »
Good afternoon,
BRAND New to this Forum.
I am having connection issues on my second attempt after reading all the forum discussions on using this Connection (OBDLink EX) prior.
I was able to make connection at my first attempt and download / create a Log, using Laptop, not App.
I just went back out to reconnect, followed OBD's instruction to the Tee, Plugged adapter in truck / laptop, turned on ignition, tried to connect, get a error message now adapter found. Light is green on adapter to which OBD instructions state ready to go, Nothing comes up ..WIFI strong..
Any help or guidance is much appreciated.
2013 F150 Platinum.
Thank you..
f-wolf
Vehicle: *** Ford ***
Post by f-wolf »
Signalsguy wrote: Mon Oct 18, 2021 10:18 pm Good afternoon,
2013 F150 Platinum.
Thank you..
Re, (OBDLink EX) and WIFI strong :?: :?: OBD Link EX is USB !!
Have you got the latest :
FIRMWARE UPDATE FOR OBDLINK EX
https://www.scantool.net/scantool/downl ... bdlink_ex/
Also try to install the driver again
Note: If the drivers for EX do not install automatically, click on the link below to download the driver.
Windows Driver : https://www.ftdichip.com/Drivers/CDM/CD ... tified.zip
And check here to make sure all is set correct ...
Signalsguy
Thank you f-wolf...
I thought I had all the updated drivers, especially since it worked perfectly out of the box so to speak.
I guess wierder things can happen.
I will try again tomorrow and see if this driver update worked.
I will advise...
Thank you for the very timely response...
Signalsguy
Good afternoon,
I have tried the updated drivers provided, I am still getting a No Adapter Found when its plugged in and a solid green light is showing on the adapter plugged in....
Very Frustrating...
Any additional comments? ODB support is not working...
scorpionul22
Vehicle: Ford Focus MK3 RS
Post by scorpionul22 »
https://www.scantool.net/scantool/downl ... yReset.exe
OBDLink USB Factory Reset Tool
Scans for all OBDLink EX or OBDLink SX devices and performs a factory reset
Signalsguy
Thank you Scorpionul22,
The settings were my issues, thank you for clarifying this for me.
Regards,
scorpionul22
f-wolf
Post by f-wolf »
scorpionul22 wrote: Wed Mar 30, 2022 1:25 pm firmware 2.6.24 for obdlink ex
Nice one !! Thank you.
jhouse55
Vehicle: 2019 Raptor 3.5 Ecoboost
Post by jhouse55 »
Hello @Signalsguy, can you post what setting you had to change to make yours work? I’m having the same problem with my EX adapter. I followed the guide and still have no luck. Updated the firmware and no difference. I know it’s not the adapter because obdwiz works just fine.
Thanks!
Signalsguy wrote: Wed Dec 08, 2021 5:21 pm Thank you Scorpionul22,
Regards,
