Black screen APIM, no power USB
Slaawek77
Vehicle: Ford Focus ST 2,0 MY2018
Post by Slaawek77 »
Hi.
Ford S-Max 2017 - after inserting the pendrive with the update Sync 3 (cyan labs), after a few seconds the message is displayed - update finished, remove the USB and the screen goes black, there is no power in the USB, the Forscan reset does not help. Apim no error code.
N czesci: JR3T-14G371-FFB
Calibration level: JR3T-14G371-FJG
Strategia: HB5T-14G374-CA
Kalibracja: HBST-14G375-FA
Will Forscan updating the firmware or recovery mode help?
Re: Black screen APIM, no power USB
remove the cable 5-10 from the battery and also create a new usb correctly and try again
Slaawek77
Post by Slaawek77 »
disconnecting the battery did not help, usb has no power
LaForge
Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
Post by LaForge »
I guess the APIM is bricked.
It was 64G and no Model 20. So CYANLABS Updater should work properly.
You have to deinstall the APIM to get it back to life on a bench.
Regrettably I cannot help in this case.
Best regards
Karsten
Changed on my 2011 Focus:
Slaawek77
Post by Slaawek77 »
This module apim in another car has no strategy and calibration.
Photo:
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
This is normal if the APIM came from a different car model however you can update it manually if the original software and calibration files are available or you can use UCDS.
Slaawek77
Post by Slaawek77 »
Ok, thanx.
can i safely put another good memory board into this broken apim?
Photo:
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Yes if you change the memory board it will normally wake up but i could bee related to eeprom being erased.
