Hi.
Ford S-Max 2017 - after inserting the pendrive with the update Sync 3 (cyan labs), after a few seconds the message is displayed - update finished, remove the USB and the screen goes black, there is no power in the USB, the Forscan reset does not help. Apim no error code.
N czesci: JR3T-14G371-FFB
Calibration level: JR3T-14G371-FJG
Strategia: HB5T-14G374-CA
Kalibracja: HBST-14G375-FA
Will Forscan updating the firmware or recovery mode help?
Black screen APIM, no power USB
- fordsmax471
Re: Black screen APIM, no power USB
remove the cable 5-10 from the battery and also create a new usb correctly and try again
disconnecting the battery did not help, usb has no power
- LaForge
- Vehicle: Focus 2011 - LaForge Edition, Modeo 2018 ST-Line
- Contact:
I guess the APIM is bricked.
It was 64G and no Model 20. So CYANLABS Updater should work properly.
You have to deinstall the APIM to get it back to life on a bench.
Regrettably I cannot help in this case.
Best regards
Karsten
Best regards
Karsten
Changed on my 2011 Focus:
Hill Assistant, Auto High Beam, Sync 3 with Navigation, Traffic Sign recognition, Lane Keep Assist,
Lane Centering Aid, Rain Sensor, Ambient & Footwell Light, FL ST-IPC, BLIS, HSW from Focus FL.
This module apim in another car has no strategy and calibration.
Photo:
Photo:
- 94C888DE-94D4-4C4B-8E4F-4BA7CFD3E3FF.jpeg (360.85 KiB) Viewed 3683 times
- E8266442-E05C-453D-B5C7-87115D8A343C.jpeg (354.52 KiB) Viewed 3683 times
This is normal if the APIM came from a different car model however you can update it manually if the original software and calibration files are available or you can use UCDS.
Ok, thanx.
can i safely put another good memory board into this broken apim?
Photo:
Photo:
- 67634745-191E-4B28-A920-013A0233D4E5.jpeg (568.46 KiB) Viewed 3673 times
Yes if you change the memory board it will normally wake up but i could bee related to eeprom being erased.
