just right after a valve body change.
now i got a P06600 code but i can acces to computer
I will add the log later....
It look like strategy 3 failded around 98%
PLEASE HELP ME MY CANNOT START
here informations :
Code: Select all
Interface:
Port: COM3, 3000000 bps
Type: FTDI
Adapter: vLinker FS v2.3.02 MIC3322 V2.3.02 (ELM327 v2.3)
Min.delay: 15 ms ( Good)
Errors:
- CAN ERROR: 9 ( 0.5% )
Vehicle:
Model: Lincoln MKX
Engine: 4V
Capacity: 3.5L
Year: 2007
Generation: 2007 MY
Fuel: Gasoline
Transmission gear: Automatic
VIN: 2LMDU88C67BJ11311
PCM - Powertrain Control Module
Part number: 7U7A-12A650-HGC
Calibration level: 7U7A-12A650-HGC
Strategy : KNBF2TA
Hardware type: 7T4A-12B684-HA
Copyright Ford Motor Co. 2009
SASM - Steering Angle Sensor Module
Part number: 7T4T-3F818-AD
Calibration level: 7T4T-3F818-AD
Strategy : 7T4T-14C309-AA
Software version: 2006-03-28
OCS - Occupant Classification System Module
Part number: 7T43-19G275-BK
Calibration level: 7T43-19G275-BK
Strategy : 7T43-14C371-BJ
Calibration: 7T43-14C372-AC
Software version: v10
4X4M - 4X4 Control Module
Part number: 7T43-7H473-AH
Calibration level: 7T43-7H473-AH
Strategy : 7T43-14C366-AE
Calibration: 7T43-14C367-AF
Software version: 2006-06-06
ABS - Antilock braking system
Part number: 7T43-2C219-BX
Calibration level: 7T43-2C219-BX
Strategy : 7T43-2D053-BX
Calibration: 7T43-2D054-BX
Software version: v9
RCM - Restraint Control Module
Part number: 7T43-14B321-BJ
Calibration level: 7T43-14B321-BJ
Strategy : 7T43-14C028-AG
Calibration: 7T43-14C098-BD
Software version: 2006-08-10
IC - Instrument Cluster
Part number: 7A1T-10849-BF
Calibration level: 7A1T-10849-BF
Strategy : 7T4T-14C026-AF
Software version: v4
Odometer: 203813.6 km(OK) [16:45:47.830] PCM Transmission Characterization Update has been started
(OK) [16:45:50.886] Transmission: 6F FWD, Current solenoid strategy number: 1021913360839, Current solenoid body ID: 1BAA19E
(WARN) [16:46:07.928] Loading file 1021913360839.6F...
(ERR) [16:46:07.937] Unable to rewrite TRID block
(OK) [16:46:11.603] Service procedure completed successfully.
(OK) [16:46:15.139] PCM Module firmware update has been started
(WARN) [16:46:15.149] Reading vehicle info...
(WARN) [16:46:15.192] Unable to read current firmware p/n, use assembly p/n: KNBF2TA
(WARN) [16:46:15.246] Unable to read current firmware p/n, use assembly p/n: 2320202
(WARN) [16:46:15.251] Unable to read current firmware p/n, use assembly p/n: NBEFJAF
(WARN) [16:46:16.221] Redirect from the function Transmission Characterization Update...
(WARN) [16:46:43.099] Total size: 1.52 Mb. Estimated duration: 2m - 4m
(OK) [16:46:46.603] FEPS programming signal has been applied
(WARN) [16:46:48.799] Loading firmware to ECU: Strategy KNBF2TA
(WARN) [16:46:48.799] Erasing sector AA (1/1)...
(WARN) [16:47:00.987] Loading block 1/2...
(WARN) [16:47:29.872] Loading block 2/2...
(OK) [16:48:36.535] Firmware loaded successfully
(WARN) [16:48:36.553] Loading firmware to ECU: Strategy/#2 2320202
(WARN) [16:48:36.554] Erasing sector BB (1/1)...
(WARN) [16:48:41.694] Loading block 1/1...
(OK) [16:51:43.259] Firmware loaded successfully
(WARN) [16:51:43.273] Loading firmware to ECU: Strategy/#3 NBEFJAF
(WARN) [16:51:43.274] Erasing sector CC (1/1)...
(WARN) [16:51:48.418] Loading block 1/1...
(WARN) [16:54:17.293] Operation failed, retrying...
(ERR) [16:54:17.822] Loading firmware failed
(ERR) [16:54:18.105] Service procedure has been interrupted
