Help needed solenoid strategy updatre failed car not start
shaders
Vehicle: lincoln mkx 2007
Post by shaders »
Strategy 3 totaly failded, car does not start again.....
just right after a valve body change.
now i got a P06600 code but i can acces to computer
I will add the log later....
It look like strategy 3 failded around 98%
PLEASE HELP ME MY CANNOT START
here informations :
Code: Select all
Interface:
Port: COM3, 3000000 bps
Type: FTDI
Adapter: vLinker FS v2.3.02 MIC3322 V2.3.02 (ELM327 v2.3)
Min.delay: 15 ms ( Good)
Errors:
- CAN ERROR: 9 ( 0.5% )
Vehicle:
Model: Lincoln MKX
Engine: 4V
Capacity: 3.5L
Year: 2007
Generation: 2007 MY
Fuel: Gasoline
Transmission gear: Automatic
VIN: 2LMDU88C67BJ11311
PCM - Powertrain Control Module
Part number: 7U7A-12A650-HGC
Calibration level: 7U7A-12A650-HGC
Strategy : KNBF2TA
Hardware type: 7T4A-12B684-HA
Copyright Ford Motor Co. 2009
SASM - Steering Angle Sensor Module
Part number: 7T4T-3F818-AD
Calibration level: 7T4T-3F818-AD
Strategy : 7T4T-14C309-AA
Software version: 2006-03-28
OCS - Occupant Classification System Module
Part number: 7T43-19G275-BK
Calibration level: 7T43-19G275-BK
Strategy : 7T43-14C371-BJ
Calibration: 7T43-14C372-AC
Software version: v10
4X4M - 4X4 Control Module
Part number: 7T43-7H473-AH
Calibration level: 7T43-7H473-AH
Strategy : 7T43-14C366-AE
Calibration: 7T43-14C367-AF
Software version: 2006-06-06
ABS - Antilock braking system
Part number: 7T43-2C219-BX
Calibration level: 7T43-2C219-BX
Strategy : 7T43-2D053-BX
Calibration: 7T43-2D054-BX
Software version: v9
RCM - Restraint Control Module
Part number: 7T43-14B321-BJ
Calibration level: 7T43-14B321-BJ
Strategy : 7T43-14C028-AG
Calibration: 7T43-14C098-BD
Software version: 2006-08-10
IC - Instrument Cluster
Part number: 7A1T-10849-BF
Calibration level: 7A1T-10849-BF
Strategy : 7T4T-14C026-AF
Software version: v4
Odometer: 203813.6 km
(OK) [16:45:47.830] PCM Transmission Characterization Update has been started
(OK) [16:45:50.886] Transmission: 6F FWD, Current solenoid strategy number: 1021913360839, Current solenoid body ID: 1BAA19E
(WARN) [16:46:07.928] Loading file 1021913360839.6F...
(ERR) [16:46:07.937] Unable to rewrite TRID block
(OK) [16:46:11.603] Service procedure completed successfully.
(OK) [16:46:15.139] PCM Module firmware update has been started
(WARN) [16:46:15.149] Reading vehicle info...
(WARN) [16:46:15.192] Unable to read current firmware p/n, use assembly p/n: KNBF2TA
(WARN) [16:46:15.246] Unable to read current firmware p/n, use assembly p/n: 2320202
(WARN) [16:46:15.251] Unable to read current firmware p/n, use assembly p/n: NBEFJAF
(WARN) [16:46:16.221] Redirect from the function Transmission Characterization Update...
(WARN) [16:46:43.099] Total size: 1.52 Mb. Estimated duration: 2m - 4m
(OK) [16:46:46.603] FEPS programming signal has been applied
(WARN) [16:46:48.799] Loading firmware to ECU: Strategy KNBF2TA
(WARN) [16:46:48.799] Erasing sector AA (1/1)...
(WARN) [16:47:00.987] Loading block 1/2...
(WARN) [16:47:29.872] Loading block 2/2...
(OK) [16:48:36.535] Firmware loaded successfully
(WARN) [16:48:36.553] Loading firmware to ECU: Strategy/#2 2320202
(WARN) [16:48:36.554] Erasing sector BB (1/1)...
(WARN) [16:48:41.694] Loading block 1/1...
(OK) [16:51:43.259] Firmware loaded successfully
(WARN) [16:51:43.273] Loading firmware to ECU: Strategy/#3 NBEFJAF
(WARN) [16:51:43.274] Erasing sector CC (1/1)...
(WARN) [16:51:48.418] Loading block 1/1...
(WARN) [16:54:17.293] Operation failed, retrying...
(ERR) [16:54:17.822] Loading firmware failed
(ERR) [16:54:18.105] Service procedure has been interrupted
Re: Help needed solenoid strategy updatre failed car not start
Post by tractmec »
shaders wrote: Sat Dec 16, 2023 6:37 pm Strategy 3 totaly failded, car does not start again.....
here informations :
Code: Select all
Interface:
Type: FTDI
Errors:
Vehicle:
Model: Lincoln MKX
Engine: 4V
Capacity: 3.5L
Year: 2007
Generation: 2007 MY
Fuel: Gasoline
Strategy : KNBF2TA
According to your screen shot your are using 2.4.8Beta!
Upgrade to 2.4.9beta and see if that helps? FORScan 2.4.8Beta had some bugs in the older PCM Strategy files writing which were reported to be fixed in 2.4.9 according to the 2.4.9 change log! Also Make sure your vLinker FS is on the latest firmware update!
This is still beta software and these Early HSCAN PCM's Firmware Updates are still in the very experimental stage so you are still doing these at your own risk!
Airborne_Ape
Vehicle: F150 Hybrid 2021
Post by Airborne_Ape »
Your adapter defaulted to 3 mbps as per your screenshot which looks too high. HS CAN operates in the kpbs range. I would download the newest version of ForScan and try locking in a lower baud rate (115 kbps) . Your current adapter settings might be incapable of negotiating a necessary network speed to complete the task is my guess.
jays_swe
Vehicle: Focus 1.8 Flexifuel 2007 125hp
Post by jays_swe »
I have the same error that i get stuck at 98%, did you solve it?
mrwildbob
Vehicle: 2008 Lincoln MKX
Post by mrwildbob »
I'm going thru the same issue error. Was this ever resolved?
