REMOTE START
turqyy
Vehicle: focus 1.6tdci titanium
Re: REMOTE START
Post by turqyy »
Crusader wrote: Tue Mar 26, 2024 10:05 am I did bypass for hood switch. Now working on Fiesta mk8
how did you do this? can you explain ? Thank u
kekela777
Vehicle: ford fusion hybrid 2018
Re: REMOTE START
Post by kekela777 »
hello
i would like to explain my situation and also get responce from pro-s.
i own 2018 fusion hybrid se
i bought key shown on photo
Screenshot 2024-05-14 171348.png (198.83 KiB) Viewed 8003 times
with is 434.2 MHz.
when key came i discovered my key is 315 MHz (my fusion is from USA)
key program is successful (originally i had only 1 key) now programed keys are (2) my original witch came with car and one witch i bought with remote start.
new programed key doesn't work it only starts car from emergency slot (confirmed).
then i enabled remote start options in BCM, IPC, SCCM, FCIM. also changed RTM xXxx from 1 to 2, still only 1 original key works starts and locks and unlocks doors but new remote doesn't.
i now thinking of buying new 433 RTM (GD9Z15607E) or i need 902 MHz key and 902 MHz RTM?
please if anyone had done on fusion hybrid se let me know what to do an stuck middle of nowhere.
Thanks in advance <3.
omar302
Re: REMOTE START
Post by omar302 »
kekela777 wrote: Tue May 14, 2024 1:22 pm i now thinking of buying new 433 RTM (GD9Z15607E) or i need 902 MHz key and 902 MHz RTM?
I am not an expert, hopefully someone more experienced will help, but my understanding is that you will need the 902 MHz key and 902 MHz RTM for remote start to work.
See this for a 2015 Edge which is very close to the Fusion. https://www.fordedgeforum.com/topic/285 ... ent-209773
kekela777
Re: REMOTE START
Post by kekela777 »
thanks for reply <3
i'll wait for more replays if nothing then am going to buy 902 key/RTM.
thanks <3
jpohlman
Vehicle: 2014 Escape 2.0 2018 Fusion Hybrid, 2020 Escape Hybrid
Re: REMOTE START
Post by jpohlman »
You're better off buying the correct FOBs and removing the "bad" ones since the car only supports 4 IAK remotes.
The right part number is 164-R8149/M3N-A2C931426
https://www.ebay.com/itm/293769157614?e ... R-q-hIj9Yw
kekela777
Re: REMOTE START
Post by kekela777 »
Thanks for reply
thats exaclty what i did
bought 902 5 button key fob same part number as you typed and also bought 902 mhz transceiver module
removed old keys program new ones configurated : BCM, FCCM, SCCM and IPC for remote start
and everything works as factory. its been a pleasure since then.
colin39
Vehicle: ford ranger 3.2cc 201bhp 2019
Re: REMOTE START
Post by colin39 »
kekela777 wrote: Tue May 14, 2024 1:22 pm hello
with is 434.2 MHz.
Ok lets start from scratch, what's the part number on your original key? Remove the key blank and the part number is on the end
antoonio
Vehicle: S-Max, 2L ecoboost, 240, 2016
Re: REMOTE START
Post by antoonio »
Hey, I was successful with remote start with my Smax 2016 with button start but question is can i get same result wit Fiesta 2018(automatic) with KEY start?? Just curious :)
kekela777
Re: REMOTE START
Post by kekela777 »
antoonio wrote: Thu Jul 04, 2024 7:31 am Hey, I was successful with remote start with my Smax 2016 with button start but question is can i get same result wit Fiesta 2018(automatic) with KEY start?? Just curious :)
hi if there were factory original remote start avalaible with fiesta "also with key start" then yes you should be able to do it
i didnot even tryied to get part numbers on fords website i searchet for 902 mhz rtm for 2018 fusion and 902 mhz remote start key for 2018 fusion and everything worked perfect.
i know some older fusion's had remote start with turn key. (also plenty videos on youtube). after remote start unlock stick key in and turn it to IGN ON.
worth trying.
kekela777
Re: REMOTE START
Post by kekela777 »
colin39 wrote: Tue Jun 25, 2024 6:32 pm
that was point i didn't knew part number :/ because car came with aftermarket key it didn't had any part number written on it.
thanks for responce
