TCU Firmware Update Failing
elpamyelhsa
Vehicle: Ford Ranger XLT MY17 PX2 w/Tech Pack
Post by elpamyelhsa »
I currently have a problem with a bricked LV4T-14G087-DB TCU after trying an incremental firmware update.
The TCU is plugged into the HSCAN3 bus, but Forscan is detecting it on the HSCAN2 for some reason.
During a firmware upgrade it sits at "Erasing block 2/2" for about 9min before failing.
The device is now bricked if anyone has some ideas. See screen shots attached.
Edit:Using FORScan 2.4.7.test20221016 and FORScan 2.4.6 beta
Firmware Error.PNG (37.01 KiB) Viewed 5863 times
Bus Info.PNG (32.81 KiB) Viewed 5863 times
Ghano38
Vehicle: Ford c max
Re: TCU Firmware Update Failing
Post by Ghano38 »
Use an old profile of your car,the TCU will show up than you can update it,if it doesn’t work contact Forscan team.
elpamyelhsa
The TCU is still detected in FORScan, but it cannot read module configuration, and all PIDs have disappeared leaving just one "Operational State". Have tried reflashing with the same error each time.
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Have you tried actual software,otherwise you have to use UCDS to bring it to live.
elpamyelhsa
Ghano38 wrote: Mon Nov 21, 2022 6:20 am Have you tried actual software,otherwise you have to use UCDS to bring it to live.
Can you clarify the term actual software?
and using UCDS seems a non-starter with sit down before reading fee structure - or am I missing something.
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
That means if the module is still visible in Forscan you should see calibration level and strategy so try update it with these levels first to bring it to live than chose the software you need,UCDS is more stable for module updating but not easy to procure due to the Russian Ukrainien conflict.
elpamyelhsa
While I have tried restoring it a few times it does keep failing with the same error after about 9min of erasing,
It looks like another SBL existed for it that may help, any chance someone has "LL5T-14G141-BC.vbf" SBL file laying around or any SBL 14G141 starting with LL5T, LV4T or LB5T?
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
The last time I had this issue with Forscan this was related to battery not enough charged to complete the procedure,whatever your case a battery charger must be used when updating modules especially(ms can,hs3 can hs4 can ones) it took me more than 45m when i updated my IPC.
For the SBL VBF files you are looking for only LB5T-14G141-BC is available.
MKK777
Vehicle: Ford S-Max 2.0L Powershift WA6
Post by MKK777 »
STA usando un interfaccia sconsigliata per forscan , per questo che ci vuole tutto questo tempo e non sono stabile : ho murato il mio ddm :oops: .
si puoi cambia cavo , prova poi a flshare in modalità recovery .spero di essere di aiuto
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
MKK777 wrote: Mon Nov 21, 2022 3:32 pm STA usando un interfaccia sconsigliata per forscan , per questo che ci vuole tutto questo tempo e non sono stabile : ho murato il mio ddm :oops: .
Sono d’accordo con te ma anche la verzione utilizzata di Forscan e multo importante.
